Tranny Leak
Old Jan 8, 2006 | 04:02 PM
KungFuDan's Avatar
Hey all started up my car today for the first time since late Oct. Has been unseasonably warm in Wi. lately. Anyways let the car run for about 20 min and moved the car around in the driveway a bit, backing and going forward. I noticed that on the tarp under the stang, there was quite a bit of tranny fluid that has leaked out over the past few months. What is the best way to stop this leak? I've never had to deal with a tranny leak before.
Old Jan 11, 2006 | 10:43 AM
chemeng's Avatar
C4 trannies are notorious for shifter seal leaks. Cheap part but you have to drop the valve body to get to it. Might also be the drain pan bolts have loosened and it is seeping around the seal. Might be a good time to change the tranny fluid and filter to see if it will help.
MikeR
Old Jan 11, 2006 | 06:29 PM
KungFuDan's Avatar
Thanks for your imput. I think I will change fluid and filter after I pull the car out for good in thie spring.
Old Jan 17, 2006 | 03:27 PM
yoruai's Avatar
I'd like to know more about this shifter seal leak. My C4 leaks horribly but only when the drive shaft is turning. On advice I've relpaced the tail shaft seal twice with no improvment. The leak is obviously comming right down the hollow of the yoke so I'm ready to replace it thinking the splines are worn.
Old Jan 27, 2006 | 09:17 PM
Rickster's Avatar
There is a bushing in the tailshaft that you'll need to replace. At one time I believe that you could buy them with the rear seal in a kit.
Old Feb 3, 2006 | 09:33 AM
BLAKE's Avatar
I know this is no kind of technical help, but every C4 I've ever run across has leaked like crazy. As long as you keep fluid in 'em they run fine. Just like a Harley, they don't leak, they "mark their territory". [img]style_emoticons/<#EMO_DIR#>/biggrinjester.gif[/img]
Gill5oh
Oct 6, 2017 10:50 PM
OneCoolGT
Dec 10, 2015 07:55 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Rando
Sep 30, 2015 12:28 PM
bconboy
Sep 18, 2015 08:18 AM
