Swapping rear end drive shaft question???
Old Jun 29, 2013 | 05:51 PM
tang65c's Avatar
I will be swapping out a four lug 6 cylinder axle for a 5 lug
eight cylinder axle. will I have to change the drive shaft or can I just
change the universal joint to make it work. Any help is greatly appreciated.
Old Jun 30, 2013 | 02:49 PM
tang65c's Avatar
Its a 65 convertible. Forgot to add that.
Old Jul 1, 2013 | 05:25 AM
matcox83's Avatar
My memory tells me the 6 cylinder is a lighter duty shaft. If it is rusty it could be weakened even more. I don't remember about the length, but all you have to do is measure. Have you searched online yet for the lengths of the two shafts?
Old Jul 1, 2013 | 12:14 PM
FMSixtySeven's Avatar
9 inch rear differentials have a different driveshaft than 8 inch if I remember correctly. We needed to get ours shortened and balanced because we switched to a 9 inch. The u-joint mount juts out farther because of the larger gearing. I don't know if you are going to do this swap, but I figured I would throw it out there.
Old Jul 1, 2013 | 01:47 PM
matcox83's Avatar
If this site is right, the 200 and 289 used the same shaft except the Hi-Po. Seems like your u-joint plan should work.
Ecostang
Nov 3, 2022 08:50 PM
chadh92
Jul 29, 2015 06:56 AM
Kev006
Jul 8, 2015 05:29 AM
