suggestions for 289
Old Sep 21, 2013 | 07:13 PM
wario's construction's Avatar
suggestions for 289
what can i do to my 289 to make it faster?
it already has an intake, 4 barrel carburator, & headers
Old Sep 24, 2013 | 05:43 PM
HOSS429's Avatar
legacy Tms Member
gears ... 3.50 or better ...
Old Sep 25, 2013 | 07:01 AM
thanks!
Old Sep 26, 2013 | 03:31 PM
Ken Ashbrook's Avatar
Hi,
Your next step is head and cam. But, if you're wanting a "spirited" street warrior, then, build for torque. It you are sticking with the 289 stroke, then heads (aluminum) no larger than 170 with a commensurate cam and TRY-Y coated headers with a carb no larger than 600 CFM. If you want more TQ & HP, stroke to 331/347, perhaps, 185 heads, cam to fit, and can still run the TRIs. But then, you'll want larger dia exhausts, perhaps, 2.5". Your carb will, most, likely need to be in the area of 650 CFM. Did I mention, you'll need "deep" pockets to fund the stroker build. Forgot to mention, you'll want to optimize your distributor operation too.
Happy Trails....
Old Oct 2, 2013 | 05:09 PM
thank you so much for your suggestions.
they have really been of great help.
i really appreciate you guys sharing your knowlegde.
Old Oct 4, 2013 | 02:35 PM
so the lower the number in gears, the better preformance?
Old Oct 4, 2013 | 06:57 PM
HOSS429's Avatar
legacy Tms Member
generally the reason for lower gears ( higher number ) is to allow you to run a bigger tire for more traction .. a 3.50 gear is considered lower than a 3.00 gear even though the number is larger .. it`s kind of backwards ... so the higher the number in gear ..the better the performance ..
Hbadger94
Sep 24, 2015 08:16 PM
robjh22
Sep 23, 2015 07:03 AM
Mustang65bob
Sep 21, 2015 11:30 AM
TripleBlack14
Sep 17, 2015 07:48 AM
haitham
Sep 8, 2015 12:52 PM
