Quick question about 200ci w/ c-4
Old May 16, 2005 | 07:51 AM
gotmy05's Avatar
I have a 67 ford with a 200ci block and a c-4 3-speed auto
I was wondering if I could buy a late model stang auto trans from either a 6 or 8 and have it bolt up to the 200ci??
I was told the bolt paterns on the block were different but what about the bell housing????
Help anyone.
Thanks, Nick
Old May 20, 2005 | 04:55 AM
ravenblack67's Avatar
Talking
You can update to the AOD. The swap will run you the cost of the transmission and the conversion parts. For a about the sam eprice, you can swap to a manual trans. Any auto trans more modern than the AOD will not work.
Old May 20, 2005 | 06:23 AM
svopaul's Avatar
Service Manager
I don't believe that any late model AOD or transmission from a V8 will bolt up to that 200. The 250 inline 6 cyl has the same bolt pattern as the V8 for the bellhousing but the 170 and 200 do not.
Old May 20, 2005 | 06:41 AM
mmoonshot's Avatar
It will not work, the bolt patterns are totally different, why do you want to do this anyway, the c-4 is a solid tranny ?
Old May 26, 2005 | 06:52 AM
gotmy05's Avatar
I just want a 4th gear. It's not in a Stang its in a fairlane I love to work the 200 and don't wanna V8 and doing 60-65 I'm hitting 3000rpm I wanna get that down to like 2100-2300. so I can get more top end speed. I also would like a little more speed on take-off. even with about 200hp from the engine its still a little slugish off the line. I mean its a lot better than the stock 120hp but I feel a tranny and rear swap would be the next best thing.
MustangConvert11
Sep 30, 2015 08:01 PM
Sep 30, 2015 07:02 PM
