Play in steering wheel
Old Jun 4, 2012 | 03:36 PM
les's Avatar
les
Watched my steering box while my son turned the wheel and my play is between the idler arm and the power steering cylinder. The bolt coming out of the cylinder has play in it so my question is does the idler arm hold that in a locked position so that it is the idler that is bad or is it signs of the cylinder needing to be rebuilt
Old Jun 4, 2012 | 04:07 PM
AlsCobra's Avatar
A Man Just Needs Some....
Man those old stangs have the sloppiest steering systems ever. You can replace everything and still have play in it. If it was my car I would convert it to rack & pinion and free yourself of those worries. By the time you finish rebuilding your system, you would have payed for the conversion. You can always keep the original system in storage for originality purposes but if you really like driving it, convert it.
Old Jun 4, 2012 | 05:20 PM
les's Avatar
les
She is original and am trying to keep it that way hence all the posts but help would be appreciated
Old Jun 4, 2012 | 05:24 PM
les's Avatar
les
The play is translating to 4" of steering wheel slop.
Old Jun 5, 2012 | 10:04 AM
skunk21's Avatar
Really sounds like the box to me.
Old Jun 5, 2012 | 11:27 AM
les's Avatar
les
Boo. I heard that is a head ache
Old Jun 6, 2012 | 10:46 PM
dmay65's Avatar
Well are all your bushing newer or no? And yes those rams go out all the time. Just had mine rebuilt on my coupe. I redid the entire suspension and it wasnt to bad. If you do it yourself that helps alot. Is the idler arm bushing good? And are the bushing on the end of the shaft good meaning the ones on the little 2 inch bracket that hangs down
Fords4Ever
2011 - 2014 GT/CS
21
Mar 1, 2021 12:22 PM
Automagically
2012-2013 BOSS 302
37
Feb 19, 2020 09:28 PM
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
earl610
Sep 6, 2015 05:48 PM
