Play in steering wheel
Watched my steering box while my son turned the wheel and my play is between the idler arm and the power steering cylinder. The bolt coming out of the cylinder has play in it so my question is does the idler arm hold that in a locked position so that it is the idler that is bad or is it signs of the cylinder needing to be rebuilt
Man those old stangs have the sloppiest steering systems ever. You can replace everything and still have play in it. If it was my car I would convert it to rack & pinion and free yourself of those worries. By the time you finish rebuilding your system, you would have payed for the conversion. You can always keep the original system in storage for originality purposes but if you really like driving it, convert it.
Well are all your bushing newer or no? And yes those rams go out all the time. Just had mine rebuilt on my coupe. I redid the entire suspension and it wasnt to bad. If you do it yourself that helps alot. Is the idler arm bushing good? And are the bushing on the end of the shaft good meaning the ones on the little 2 inch bracket that hangs down
robjh22
Sep 8, 2015 12:31 PM
Sep 8, 2015 10:45 AM
