Need help
Old Nov 14, 2012 | 10:58 AM
drumr90's Avatar
Need help
Ok i had a bad fuel pump changed that and all new fuel lines. Now car started and ran with choke for about 2 min and i nocked choke off. Now since i did that car will not fire up all spark plugs, cap, roder, and points look fire. Coil is brand new also. Could it possibly be a miss tune due to lack of fuel and all from bad pump for yrs.
Old Nov 14, 2012 | 11:22 AM
so it does fire up? Correct....just not firing on all cylinders? Is it back firing or does it seem like its not getting enough fuel?
Old Nov 14, 2012 | 02:28 PM
drumr90's Avatar
It dosent fire no more. It sputters like it wants to but just wont fire.
Old Nov 14, 2012 | 02:59 PM
drumr90's Avatar
I just tried now to start it. I turn on electric choke for little then boom it fires but once it runs the fuel thats in bowls it dies.
Old Nov 15, 2012 | 10:40 AM
dmay65's Avatar
Ok so you can see the bowls run to empty? Possibly stuck floats, timing got thrown off, maybe even something got picked up from a dirty tank and only gets enough fuel when it's revving and pushing more fuel. Check air fuel ratio also. Just Continue that check list
Old Nov 15, 2012 | 11:04 AM
Yea I would look to see if the carb/floats/needle and seat are gummed up
Old Nov 15, 2012 | 07:23 PM
drumr90's Avatar
Ye i was gunna pull carb apart and see possible causes.
