My First Mustang (with a lot of lessons)
Old Jul 24, 2008 | 01:40 PM
  #41
Wolfsburg's Avatar
I, for one, am certainly interested. I've a feeling yours is a path I will eventually travel down.
Old Jul 24, 2008 | 03:50 PM
  #42
the procrastinator's Avatar
Definately keep posting if you have the time. This is very interesting stuff!
Old Jul 25, 2008 | 03:14 PM
  #43
flight96's Avatar
Yes PLEASE...Keep on posting !!! I'm just about to start my '69 vert reconstruction and I'm sure some of this info will help me out a lot !!!
Old Jul 26, 2008 | 12:03 AM
  #44
newdy22's Avatar
Thumbs up
Originally Posted by gc65restomod
Is there interest in me continuing this thread? I am not too good at this stuff but I will stay with it if you guys find any value in what I post here.
Thanks in advance for the feedback.
Oh yes... please keep posting. You're doing a fantastic job!
Old Jul 26, 2008 | 12:21 AM
  #45
69CaliStang's Avatar
Yes, Please keep up the good work!!!
Old Jul 26, 2008 | 11:46 AM
  #46
gc65restomod's Avatar
Thanks for the replies, so here we go.
With so many fit issues on both the front and rear wheels some ideas were tossed around to address the situation. One idea was to flare the fenders.
I really wanted to avoid the flares to keep my original theme and not make the car look like a pro street dragster. The alternative was to bead the fender wells (cut the lip and weld 3/16" brake line along the edge for a buffer) to gain some space but leave the original appearance on the outside. This would add about 3/8" and the rest of the problem would be solved by milling the front wheel backspacing down 1/2" and narrowing the rear end 2 inches. Smaller tires could be used as a final trick if necessary. That actual work would come later in favor of working on some of the body panels.
Back on the rear of the car the fit issues on quarter panels and wheelhouses were corrected.
The left side was done first as this would be good reference for some fit problems on the right door post left over from the damage that was discovered earlier. After some manipulation, the taillight panel and quarter panel fit well together.
T
he biggest problem was at the door post. The difference was this side was about 1/8" too long. The weld edge was rolled back using a hammer and dolly then the panel and door post lined up nicely. On the top of the quarter panel at the rear deck panel, body filler was ground out and a lot of rust revealed underneath. This panel would have to be replaced.
For the door post brackets were built to hold the door post in place. The bottom of the post was sliced to get some working room and moved forward to match the other side. The problem was solved.
The doors were then bolted on to check the progress of the work. The gaps looked really good all the way around. It was starting to look like a car again.
Even with the bottom of the door blown out by rust it aligned nicely with the rocker.
All body panels were looking good. The body lines were nice and straight and on the right side the panels were also looking pretty good. There was good alignment of panels and consistent gaps. This was a good sign for a first fitting.
Old Jul 28, 2008 | 02:54 PM
  #47
hiznherponies's Avatar
Wow!!It's starting to look like a Mustang again!! Great work, btw!!
Old Jul 30, 2008 | 09:45 AM
  #48
Some more fit issues - Wheelhouses Suck!
With the panels looking good it was time to go back to the problems of fitting the wheelhouses. The flange around the top was misaligned to the floor. It was actually out away from the floor over half an inch. The rear portion of the flange was reworked to move it over to sit flush with the side of the floor.
Fitting the outer wheelhouse more problems were encountered. The bottom corner of the wheelhouse was too large to fit inside the rocker panel. Once the wheelhouse was in place, the fit to the quarter panel was checked and then the two parts fit together in the car.
After some manipulation of the outer and inner wheelhouse panels, they were reassembled but the alignment was still off a bit. Another problem developed when the wheelhouse was reshaped as it affected the fit to the quarter panel. It was necessary to slice the outer lip of the wheelhouse to realign it to the quarter along the rear third of the opening.
In the front, the bottom corner of the wheelhouse was reshaped and fit much better inside the rocker panel. The quarter panel, wheelhouse panel and rocker panel were finally all in place.
Alignment of the wheelhouse panels was improved, but still needed some work. The flange on the inner wheelhouse was barely over the flange on the outer panel. It was at this point it was pulled apart and the flange was re-arched on the inner wheelhouse to bring it up to fit the outer panel.
With all the changes made in the wheelhouse panels and the outer edge cut to help the wheelhouse fit the quarter panel, it was all pinned together.
With the pins in place the parts were removed and prepped for welding and reassembled exactly as they would be in final positioning. One side down and one to go…..
Old Jul 30, 2008 | 11:45 AM
  #49
flight96's Avatar
How are you welding the quarter panel to the wheelhouse? Bead or spot ? Pictures would be great if you have them.
Old Jul 30, 2008 | 10:10 PM
  #50
Every possible effort is being made to prevent the car from rusting again. This means every weld is prepped welded completely, seam sealed and then coated with rust encapsulator. I did not get photos of this specific area of the welds.
Old Jul 31, 2008 | 06:49 AM
  #51
svopaul's Avatar
Service Manager
The fitment issues you are having are directly related to the quality of parts you received from your suppliers. While we occasionally have to tweak things here I have never had the kind of fitment issues you are experiencing. This goes to show that there are different grades of available replacement and repair parts. The Dynacorn parts I have been using in my shop have never had these issues....we have had to do some adjustments on a couple of pieces and the wheelhouse was one area but it was nowhere near the problems you experienced.
Good luck and keep up the work!
Old Jul 31, 2008 | 07:31 AM
  #52
I am kind of in a 50 / 50 situation with the Dynacorn parts. Many of them are and many are not. Unfortunately, this is one of the major lessons of this build. Parts do matter and going with the cheapest will not necessarily save you money. This thread is behind the actual build and I am trying to catch up so it is a lesson too late to benefit me but hopefully other people here learn from it.
Thanks,
Old Jul 31, 2008 | 07:36 AM
  #53
Sorry I forgot to mention......
This particular weld is not complete. The edge of the quarter and wheelhouse needs to be modified for the rear suspension. I will post some photos of the area when that comes.
Old Jul 31, 2008 | 08:10 AM
  #54
svopaul's Avatar
Service Manager
Thanks,
I agree with you....it is a little late once you get to the point of making the parts fit and that is most definitely unfortunate. The problem in my opinion lies with the parts suppliers.....they should know what they are selling and most often do not or do not care and they should want to sell you the best fitting parts but often they don't car as long as they are selling parts. Few companies take the position of refusing to sell the junk stuff....I am one of those few. While my primary business is not parts sales I do try to steer customers to the better parts. Years ago when they came out with the 79-86 Reproduction Dashpad I got one and refused to sell them because the quality was(and still is last I checked) awful...it weighed 15lbs and if you held it in the middle the 2 sides would try to touch each other...that was on top of the wavy appearance that never got any better....better than nothing I suppose but I don't want to sell something that I know the customer will not be 100% happy with. Similarly with the vintage Mustang parts....if I've used something I have found to be inferior then I will not recommend it to anyone.....if more people took this position it would not only force suppliers to make better parts but it would also save people like you a lot of aggravation and money.
Old Aug 4, 2008 | 08:41 AM
  #55
Passeger side wheelhouse fitting.....
Now it was time for the passenger side to go together. First, the inner wheelhouse was placed. The rear portion of the weld flange had to be moved over like the driver's side.
The outer wheelhouse went in much easier than the other side, so the quarter panel was fit right away. Aside from moving the weld flange over, the panels lined up pretty well. Some more skillful manipulation and everything fit right up.
After pinning it together…
You can see that the tire was pretty close already with the 58" axle. The floor needed to be moved inward to the scribed line you see in the photo. After a little hammer and dolly work, the flange had been moved over on both sides. There was no trouble pulling the wheelhouse over to fit the new shape. Everything went back together nicely.
This left plenty of room for the tire to move in after the rear suspension would be narrowed an inch on each side.
With all the work on the outer panels done, it was time to get bracing in the car again and make it all work together properly. There were some minor modifications necessary to get around the wheelhouses in their new position, but nothing too difficult.
It really went together well and was ready to be disassembled to punch the holes for spot welds. The next time it went in the car would be permanent.
Just to make sure everything would work in the end, the rear seat was checked for fit. No problem there.
The next step was to remove the rear deck panel that would be replaced. This exposed the very last of the nasty rust. There was absolutely nowhere left for the rust to hide. That was a great feeling to know that the problem would soon be eradicated.
Old Aug 4, 2008 | 08:43 AM
  #56
a few more photos of that work
enjoy
Old Aug 5, 2008 | 02:48 PM
  #57
NO MORE RUST IN MY MUSTANG!!!!!!!
The day I have waited for from the beginning of the build finally arrived. The day I could say that there was no rust in my mustang. Honestly, I was not sure I would ever see it. The car was moved to the sandblasting area for the final time to remove the rust from around the rear structure and the paint from the remaining body. It made a huge difference to the look, but did expose some rusted out areas around the edge of the roof opening that had to be repaired on both sides.
The last of the paint came off the cowl and dash next. After sandblasting, the cowl appeared so much more solid and ready to do its job. The ignition switch was still in place in the dash so it was masked off and blasted around it. The keys were misplaced through the cars moving around and years of not running so a locksmith would need to be called in to make a new key so the tumbler and bezel could be removed from the car.
As the blasting proceeded outside, all the panels for the rear of the car were prepped for spot welding and then the car was brought back into the shop for assembly. The tray that fits inside of the rear structure was fit in place and welded.
Repairs then started on the last rust damaged parts of the structure. After cutting out the damaged area and forming a repair panel it was tack welded in place. You can see the difference between the completed repair on the driver's side and the damaged panel that was removed. The same process was repeated for the passenger side.
Then it was off to the paint booth for multiple coats of epoxy primer. All of the bare metal was recoated in addition to the sealing that was performed along the way. The dash and all the welds on the floor were primed as well.
In primer, the repairs on the rear structure looked nearly perfect. It was too bad no one would ever see that part of the body again.
Old Aug 5, 2008 | 02:50 PM
  #58
a few more photos......
I know this is a lot of detail so bear with me.....
Old Aug 8, 2008 | 07:36 PM
  #59
Wolfsburg's Avatar
Congrats on the farewell to rust!
Old Aug 8, 2008 | 07:54 PM
  #60
GrnT's Avatar
Man that alot of work and money but its looking real nice with all the rust gone.
