Mustang 4 speed question
Old Sep 11, 2012 | 05:14 PM
x21's Avatar
x21
Question Mustang 4 speed question
Hi all, it's been a very long time since I last posted anything on this forum, but I was getting the itch to get back into the classic mustang game. My question is- How big of a difference would it make if I used a toploader made for a 390 in my 1969 Mustang with a 351W? I have only owned slushboxes, but I'm trying to understand these toploaders. Other than the tag, I dont see much of a difference. Any help is appreciated- Thanks ahead of time.
Old Sep 13, 2012 | 08:17 AM
HOSS429's Avatar
legacy Tms Member
you just need to make sure you have a clutch and drive shaft to fit the input and output shafts .. a friend used a 428 4 speed behind a 289 years ago .. had to use a 428 clutch i think .. bigger shaft ..check you pilot shaft bushing also
Old Sep 15, 2012 | 09:25 AM
x21's Avatar
x21
Thanks for the response. The best I found was on wikipedia, where it gave me a longer length for one in particular that I was looking at. Apparently 1969 and up the 4sp toploaders go from 26" to 29" in length. Input shaft and output splines remain the same. I am guessing it may be due to a longer tailhousing? Are those fairly interchangable (assuming I could find one)? Otherwise, I guess I can get a driveshaft meant for a 390- equipped car.
Old Sep 15, 2012 | 11:50 AM
FMSixtySeven's Avatar
I had a similar problem with my 1967 Mustang. The engine is a 1968 Shelby GT 350 (302). The C4 transmission case is from 1968, but I believe the guts or just the tail shaft is from a 70's model (don't know how that happened). This caused some problems with the driveshaft. The driveshaft was about 2 to 3 inches too long. We took it to a repair shop and they cut a section out of it and rebalanced it for us. It ended up costing less than getting a new driveshaft. I wouldn't recommend getting a used driveshaft, you never know what could be wrong with it or how strong it is anymore.
Old Sep 15, 2012 | 02:42 PM
matcox83's Avatar
If you have a driveshaft (or 2 if doing a swap) with the right yokes, a custom link shaft is very cost effective.
Jim74656
May 1, 2023 02:15 AM
ssjbuu
Aug 28, 2015 08:55 AM
Mackitude
Aug 13, 2015 01:05 PM
AMWill
Jul 20, 2015 08:40 AM
Extremespeedtrackevents
West Coast
Jul 9, 2015 11:26 AM
