Lifter question... Please help.
Old Jun 5, 2012 | 05:24 PM
mhaymes67's Avatar
I have a ticking noise in my engine. I've been trying to find an answer, and today I took it to a shop to have it looked at. They say that I have a sticky lifter. I think I have the bad lifter located (far back passenger side) . I don't want to spend $500 replacing a $5 part. So, I've been looking into replacing it myself.
Everything I read says that I have to remove the intake manifold to remove a lifter. I can't figure this part out. I've read that you remove the pushrods (i know how this is done) and use a strong magnet to pull out the lifter through the hole where the pushrod was. If this is the case, why the need to remove my intake????? Am I missing something?
I appreciate all responses, even the ppl who think I'm a moron for not knowing this answer. Haha.
Old Jun 5, 2012 | 05:28 PM
mhaymes67's Avatar
Oh, I'd like to add that my car is running great and ,after all the work I've done, this ticking noise is driving me crazy
1967 mustang coupe
289 2v
Old Jun 6, 2012 | 06:24 AM
HOSS429's Avatar
legacy Tms Member
the hole in the intake that the pushrod goes thru is about half the size of the lifter .. i have not fooled with that old an engine in a great while but you need to know if you have an adjustable valve train .. if so you may just tighten down the offending lifter a bit .. if not and i wouldn`t be affraid to do this myself but some other motor purest on here will scoff .. find the loose rocker ( due to the partially collapsed lifter ) and put a very thin shim ( washer )under the nut that holds the rocker down .. you may have to try several thicknesses to get the lifter to snug up and get quiet .. but dont use any washer thicker than about .030 .. .. it is a crutch but may be a fix .. iv`e done it with success
kennyg
Aug 14, 2023 11:45 AM
Kalel08
Sep 29, 2015 03:06 PM
dakotawolfe
Aug 26, 2015 04:01 PM
missc1115
Aug 26, 2015 07:56 AM
spqr
Aug 10, 2015 01:37 PM
