Jack Stands With A '66 Coupe
Old Feb 17, 2008 | 02:59 PM
SINBUSTER007's Avatar
i have a question. i will be getting a 1966 coupe in march to clean for someone so they can sell it. seeing that a cleaning both inside, outside and underneath is in store what is the best way to jack the car up and put it on jack stands so i can clean it? any suggestions or info? thanks..
and if your interested, its a 1966 coupe, auto, 85+/- original miles, original interior, 289 2v V8, springtime yellow with vinyl top (not on the car at this time)
Old Feb 18, 2008 | 10:25 AM
BA Mustang's Avatar
Once i get an answer i will tell you.
Old Feb 18, 2008 | 12:23 PM
BA Mustang's Avatar
Here is answer i got. "Anywhere on the actual frame should be fine, as well as the rear diff. Just don't put it under the sheetmetal and expect that to hold unless you've got some frame behind that metal. "
Old Feb 18, 2008 | 12:44 PM
Knight's Avatar
Needs to be more Astony
I used to put my car with 2 jack stands on the front frame rails and then two under the axle and the jack under the diff.
Old Feb 19, 2008 | 10:33 AM
codeman94's Avatar
same here...
Feb 10, 2017 07:12 PM
CiniZter
25
Apr 28, 2016 05:41 PM
