How would you go about filling the rear valence?
Old Nov 16, 2004 | 11:29 AM
Jay's Avatar
Jay
I picked up a great condition original valence. I want to fill the openings for the backup lights. Can someone provide some ideas on how to do this properly so it will hold up? Welding technique to use? Source of patch metal?
Decided I will likely put a fiberglass rear bumper on and recess some type of back light under it.
Old Nov 16, 2004 | 12:08 PM
jpony645's Avatar
Take a piece of 16 gauge sheetmetal and trace the opening on it. Cut to fit inside the opening. Tack weld in several places. Connect welds with a small bead (1/2"). Metal finish. Apply thin film of filler if needed.
Body shops are a good source for small scraps. Most metal shops want to sell whole 4x8 sheets. I hung on to the leftovers from my patch panels to use in the future.
Old Nov 16, 2004 | 12:20 PM
BLAKE's Avatar
I'd cut square patches out of the scraps, then trace around the round backup light holes. That way it's easy to know where to cut the valance, and easy to align the patch panel. This is what I did when I shaved my antenna.
Old Nov 16, 2004 | 12:23 PM
jpony645's Avatar
Cut the valance instead of trimming the patch to fit? :scratch: That'd work too. Probably easier that way, Blake.
Old Nov 16, 2004 | 12:35 PM
Jay's Avatar
Jay
How about flanging the patches and drilling holes in the flanges. Then spot welding the patch from behind to hold it, followed by a bead to fill from the front. Grind and then fill? I'm trying to remember if there's some tough contour to match to the panel or if it is indeed flat there...
We're getting there
Old Nov 16, 2004 | 01:57 PM
jpony645's Avatar
If there is a contour, it shouldn't be so much that you couldn't bend the patch to fit it.
The flanging will work just as well and may actually be stronger. I just prefer butt-welding when possible.
Old Nov 16, 2004 | 02:10 PM
BLAKE's Avatar
Agreed on both points.
Rando
Aug 25, 2021 11:12 AM
kponypower
Jun 17, 2020 07:17 AM
GLOCKer
Sep 28, 2015 05:20 PM
Evil_Capri
Sep 25, 2015 12:56 PM
