Hood pin installation Help!
Old Mar 1, 2005 | 08:25 AM
cyoda44's Avatar
I want to install these hood pins on my 05 mustang. Does any one have first hand knowledge of the installation? Are these brackets the proper underside attachments? Thanks in advance :worship:
Old Mar 1, 2005 | 07:11 PM
Oboebrian's Avatar
There are "u" brackets that mount from the underneeth sid of the hood that clamp the lock onto the hood.
there is also a main bracket that mounts to the 72 radiator support.
Then a retention clip that bolts to the main brackets that retain the hood loks when the hood is closed. (as can be seen bolted to these brackets)
Look at NPD or www.mustangsunlimited.com for all the hardware at a lower price.
Some Picts of the original type installation can be found here:
http://www.429mustangcougarinfo.50megs.com...ng_exterior. htm
I'm not sure if you can modify them to fit an 05 (since i haven't seen one up close since the prototypes).
I hope this helps!
Brian
www.desertmustangs.com
Old Mar 2, 2005 | 02:30 AM
SuperCJ's Avatar
Can you please post some pictures of this modification when you are done? I am considering this for my future 05 as well.
Old Mar 2, 2005 | 08:14 AM
BLAKE's Avatar
Cool! Somehow, I knew Oboebrian would come to the rescue on this one.
Old Mar 2, 2005 | 12:10 PM
cyoda44's Avatar
Brian Thanks!!! :worship: :worship:
JonsMustang
Mar 5, 2016 05:44 PM
seaclam
Sep 25, 2015 01:29 PM
tbear853
Sep 8, 2015 11:18 PM
jim010
Sep 7, 2015 02:40 PM
SMOKE46
Sep 6, 2015 09:40 PM
