Help me decide
Old Feb 3, 2005 | 10:17 PM
one2gamble's Avatar
on whether or not I want to cut my drip rails off, its really buggin me. I have everything else shaved, the lower rear valence is welded in so theres no seem, the seem on the rocker to 1/4 is smooth and so are the little seems between the qt to the little part under the window. The only thing that isnt or wont be smooth is the cowl vents and the headlight housings.
Having the drip rails removed isnt cheap but I can commit even though I think in the end I would be happier with them gone.
Old Feb 4, 2005 | 07:46 AM
BLAKE's Avatar
Sure, shave 'em.
Old Feb 4, 2005 | 09:18 AM
LMan's Avatar
Ive always preferred em shaved as well B)
________
Vaporizer-Info
Old Feb 4, 2005 | 09:56 AM
Stroked66's Avatar
I like ‘em shaved as much as the next guy , but you need to keep in mind, that the sealing system used on these old Stangs were designed to be used WITH drip rails. Once you shave them, there’s no going back. Not only will you need to be very careful when washing, but chances are you’re gunna have problems with wind noise (a new set of seals will go along way to minimize this).
Good luck!
Old Feb 4, 2005 | 10:49 AM
LMan's Avatar
Originally posted by Stroked66@February 4, 2005, 10:59 AM
Once you shave them, there???s no going back.
...thats what I tell em.......
________
NEXIUM SETTLEMENTS
Old Feb 4, 2005 | 12:28 PM
pakrat's Avatar
I don't mean to stubble into this thread, oops I mean stumble , but this is one of those tough irreversible things to do so think long and hard about it, they won't grow back like other things.
Have you seen up close and or driven in a car without them yet?
Old Feb 4, 2005 | 01:21 PM
one2gamble's Avatar
i have seen them up close but never driven a car without them. The issues already brought up are the issues that have prevented me from taking the plunged. The only thing I dont really understand is how the drip rail will supposedly reduce wind noise, the only thing I thought it was for was to keep the water out. Its not like the rubber seal will suddenly be gone.
Old Feb 4, 2005 | 01:48 PM
jpony645's Avatar
Old Feb 4, 2005 | 01:52 PM
BLAKE's Avatar
Originally posted by LMan+February 4, 2005, 11:52 AM--><div class='quotetop'>QUOTE(LMan @ February 4, 2005, 11:52 AM)</div><div class='quotemain'><!--QuoteBegin-Stroked66@February 4, 2005, 10:59 AM
[/b][/quote]
I don't get it?? :scratch:
Old Feb 4, 2005 | 01:56 PM
bnickel's Avatar
[quote=one2gamble,February 4, 2005, 2:24 PM]
it creates a low pressure area of sorts around the window which helps to reduce the wind noise. i have actually SEEN how this works, as a smoker when i used to actually drive my car, with the window open only about an inch or so i could flip a butt out of the car and if i did it just right you could actually watch the butt "hang out" in that low pressure area for a second or two before it went away, without the drip rail there that low pressure area will be gone which will allow the air to move over the car closer to the window thereby increasing wind noise. look at any newr car that is actually a hardtop and you will find drip rails. all of the newer cars that don't have drip rails are "sedan" bodies meaning they all have the doors with window frames built in. does that make any sense?
Old Feb 4, 2005 | 03:06 PM
jpony645's Avatar
Originally posted by BLAKE+February 4, 2005, 2:55 PM--><div class='quotetop'>QUOTE(BLAKE @ February 4, 2005, 2:55 PM)</div><div class='quotemain'>
[/b][/quote]
Then you don't shave 'em.
Old Feb 4, 2005 | 03:25 PM
one2gamble's Avatar
It makes a lot of sense and it really wasnt something I had thought about. Do you think if I rolled the rail, similar to how they do on a lot of the old rods it would still create the low pressure area while giving me a smoother look that I am after?
Old Feb 4, 2005 | 04:34 PM
bnickel's Avatar
i don't know i'm not up much on the old rods, got any pics?
Old Feb 4, 2005 | 04:50 PM
one2gamble's Avatar
this is the closest pic I can find though this is a glass car
http://www.gahotrods.com/images/34coupe9.JPG
tukatz
Off-Topic Chatter
23
Oct 20, 2015 09:54 AM
mabupa
Sep 23, 2015 12:17 PM
50Cal
Sep 16, 2015 03:54 PM
Road_Runner
Sep 10, 2015 01:14 PM
Road_Runner
Sep 10, 2015 11:28 AM
