Help Identifying a Part
Old Dec 4, 2011 | 08:43 AM
ghostsin's Avatar
Hi everyone, brand new here. I have a 1966 Mustang I6 200 that I'm just getting started on. I've replaced most of the lines and hoses but I'm having a hard time identifying the line pictured. I've highlighted the area in red.
Could someone tell me what the technical name is so I can order a new on? Thank you all!
Old Dec 4, 2011 | 08:55 AM
HOSS429's Avatar
legacy Tms Member
does the car have power brakes ? looks like the vacuum feed for that ..
Old Dec 4, 2011 | 09:01 AM
ghostsin's Avatar
It does have power brakes. There seems to be coolant coming out of the hole when I start it though. The pic I used is not my carb. Mine is missing the piece all together.
Old Dec 4, 2011 | 09:16 AM
ghostsin's Avatar
oops, it has manual brakes actually.
HOSS429's Avatar
legacy Tms Member
if it has coolant coming out it must be a port for your heater system .. but you may have that running under your carb .. if you say the tube is missing it probably was never there to begin with .. ive` seen some just now on google with a plug in that spot ..
Old Dec 4, 2011 | 09:29 AM
ghostsin's Avatar
thank you for checking that for me, Roll Tide!
Old Dec 4, 2011 | 01:41 PM
BA Mustang's Avatar
Yeah that is not necessary to run. My 200 didn't have one
Old Jan 5, 2012 | 04:47 PM
drmathewda's Avatar
Good choice...that's a picture of my car.
Old Mar 6, 2012 | 12:53 PM
matcox83's Avatar
The line shown is the vacuum line that would go to the automatic transmission and/or brake booster, if so equipped. If your car is running right you must have manual trans. There should not be coolant coming out of that hole. As someone stated earlier, there is a coolant passage in the carb spacer, but that has 5/8" heater hose attached to both sides.
Steve@CJPP
Sep 24, 2015 06:58 PM
Airborne42
Sep 24, 2015 11:01 AM
Sep 10, 2015 08:31 AM
Steve@CJPP
Sep 3, 2015 10:43 AM
