Fuel Pump problem?
Old Sep 2, 2012 | 02:48 PM
pony4bt's Avatar
Fuel Pump problem?
My 1965 started up fine, but then died. After a few more try's...starting and dying, it wouldn't even start up/turn over. I fed gas into the carb and it started up again, but died again. The tank is half full. Does this sound like the fuel pump is failing??
Thanks-Bill
Old Sep 2, 2012 | 03:08 PM
drumr90's Avatar
Sounds like it to me. Or could be a clogged fluel filter.
Old Sep 2, 2012 | 03:10 PM
How fresh is the fuel?
Old Sep 2, 2012 | 11:42 PM
mustang-68's Avatar
It sounds like a fuel pump
Old Sep 3, 2012 | 11:54 AM
pony4bt's Avatar
Thanks all for the input... The fuel is old...that's true. I was wondering that too, but wouldnt it run poorly rather than simply die? I will replace with new gas and a fuel pump as well. Hope it works! Thanks again!
Old Sep 3, 2012 | 12:24 PM
HOSS429's Avatar
legacy Tms Member
before you go thru the trouble of putting a new fuel pump on check it .. take the fuel line loose from the carb and point it into a large container of some kind and spin the engine over a bit .. see if it pumps ,, make sure to unhook the ignition coil .. dont want a spark with fuel running about .. and actually smell of the gas .. if it smells like gas it most likely is ok .. if not it`s def old ...
Old Sep 3, 2012 | 05:20 PM
drumr90's Avatar
Or we did this with myn wile the tank was out. Run a line from a jog of gas to ur carb and see if she cranks and runs good.
Rando
Aug 25, 2021 11:12 AM
09-gt/cs
Oct 15, 2015 10:03 AM
boz
Oct 1, 2015 04:47 PM
Sep 16, 2015 06:44 PM
