frozen 68 brake caliper
I am trying to rebuild some 68 brake calipers and the pistons are stuck in the caliper. Any ideas on how to get them out to rebuild?
Thanks,
Jeff
Thanks,
Jeff
legacy Tms Member
if they are still on the vehicle remove the pads and smash the brake pedal .. see if the master cylinder will push the piston out .. if you have them off the car use a clamp to try and push the piston in a bit to free it up .. if that does`nt work try to find a safe way to apply some air pressure to them .. dont let the piston hit you if/when it pops out ..
