Eliminate the original starter solenoid?
Old Feb 4, 2005 | 11:42 AM
66HertzClone's Avatar
I have a Ford mini starter in my car, since it has the starter solenoid on the starter the original solenoid has become a junction block so to speak.
It seems like it would not take much effort to rewire the underhood area and make it disappear. It sure would look a lot better than having it hanging on the inner fender.
Do you think this is possible to do?
Old Feb 6, 2005 | 07:10 AM
ravenblack67's Avatar
If you are going to show your car, that may be a mistake. If not showing, simply remove the starter relay and fill the holes. Lots of folks call them solenoids but they are relays.
Old Feb 6, 2005 | 12:37 PM
Livewire's Avatar
Relay-A device that responds to a small current or voltage change by activating switches or other devices in an electric circuit.
Solenoid-An assembly used as a switch, consisting of a coil and a metal core free to slide along the coil axis under the influence of the magnetic field.
Seems relatively the same in this case to me...
I would say elimination!
Old Feb 7, 2005 | 09:50 AM
LMan's Avatar
ask Cloney. If anyone knows this, it would be him.
________
DEPAKOTE SETTLEMENTS
Old Feb 7, 2005 | 12:58 PM
one2gamble's Avatar
id ditch it if you could, its ugly
May 3, 2026 05:42 AM
Sep 30, 2015 07:02 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
