The classic why is my Mustang running hot?
Old Jul 30, 2004 | 08:12 AM
VintagMustang302's Avatar
I got the car back from the radiator shop and I don't have a blown head gasket. They told me the that my cooling system is operation fine other than they feel that the electric fan is not pulling enough air. I decided to go back to the mechanical flex fan and an electric pusher fan. I hope this will keep it cool. I'll let you guys know if this fixes the problem.
Old Jul 30, 2004 | 10:02 AM
pakrat's Avatar
UM, a stock puller and a pusher do not mix. I would think twice about that. Despite what common sense might make you think, it cuts your flow in half, not doubles it.
Old Jul 30, 2004 | 10:24 AM
jpony645's Avatar
He has a point. The pusher will block flow through the radiator, if it's on the front, which I assume it is.
Old Jul 30, 2004 | 10:29 AM
GT350Clone's Avatar
I've used a small pusher in front, with an engine driven fan behind for 3 years now.
The only time you really run the pusher is sitting in traffic/parades, when there isn't enough airflow. It does not block airflow at speed.
Old Jul 30, 2004 | 11:16 AM
jpony645's Avatar
:bang:
I stand corrected.
Old Aug 1, 2004 | 12:58 AM
obsesive23's Avatar
I know it sounds dum but is the fan blowing correctly? I hooked mine up backwards to start on my truck :bang: Also have you tried using "water weter" it droped my temp by 11 degrees. Good luck and I'm sure that this is not your problem.
Old Aug 1, 2004 | 08:03 PM
Sharp's Avatar
You might have the wrong water pump. One for a serpentine drive system spins opposite of one for a v-belt. I'm not 100% sure about that but it can be easily checked by going to the parts store and having them pull one of each out of the box and looking at the impellers.
Mackitude
Aug 13, 2015 01:05 PM
Jul 20, 2015 06:26 AM
AMWill
Jul 16, 2015 04:26 PM
BillyDaKid
V6 Performance Mods
Jul 15, 2015 12:50 PM
