Carb Spacer?
Old Aug 4, 2006 | 09:09 PM
codeman94's Avatar
Carb Spacer?
I've been thinking about getting one for a while cause I heared that they add horsepower by tricking your engine into thinking you have a high rise intake...but I guess my question is...is it worth it?....they are a little less than $50...but how many horsepower do they really add....5?...I was thinking about a 1 inch....I already have the Edelbrock intake and carb. Also...how hard is it to install....I'm guessing not hard. Thanks.
Old Aug 12, 2006 | 07:46 PM
codeman94's Avatar
I suppose I'll hold off since no one is telling me to go for it..
Old Aug 13, 2006 | 06:26 AM
for fuel injection engines they will do nothing for carbed engines they are supose to add a few hp. Very easy to install. unbolt the carb slap that baby in there with a gasket and bolt the carb back up.
Old Sep 6, 2006 | 01:01 PM
kjacobson351's Avatar
I was going to add one to my windsor ( I heard up to 15hp on very high RPM applications but about 5 under regular use. I ended up not using it because i didn't have enough hood clearance. not only are the good for better atomization of the fuel but they also insulate your carb from your engines heat which keeps your fuel from boiling. They look real mean on a ford small block, but what is also good is a heat shield it gives you some hight and there are several metal plates and gaskets that bolt under the actual shield that really insulate your carb. but I would look into it.
Some people also just bolt it on. but I prefer studs they line everything up it makes things easiar I think. I hope i helped
Old Sep 13, 2006 | 09:56 AM
Spoofty's Avatar
You will also need longer carb studs to go with the spacer.
Old Oct 7, 2006 | 06:49 PM
codeman94's Avatar
ok...so I think I'm going to do this....but how do I know which one to get?...some of them are open...some divided down the middle...and some are restrictor plate style with four holes.....I have a Edelbrock 500cfm carb...and a dual plane Edelbrock Intake....which one?
1.
2.
or 3.
Old Oct 7, 2006 | 07:43 PM
karman's Avatar
Here is some more info. for you.
http://www.hotrod.com/techarticles/carburetor_spacers/
http://www.cantonracingproducts.com/...c/spacers.html
http://www.corvettefever.com/techart..._spacers_info/
Hope that helps.
Old Oct 7, 2006 | 08:55 PM
codeman94's Avatar
Thanks Karman.....so I guess id doesnt matter?? I thought I needed to get the right one or else it wouldn't fit......well...If it doesnt matter for fit purposes.....I think I want the 4 hole one.....for more low end beastliness.
Old Oct 8, 2006 | 07:17 PM
Every_Mn's Avatar
Low end beastliness is always good...
MrSylphie
Aug 18, 2015 08:40 PM
Wild5.0
'10-14 Exterior Modifications
15
Aug 4, 2015 11:22 PM
nismos13s14
1994-2004 V-8
Jul 31, 2015 07:40 AM
LuiG31
Ecoboost
Jul 20, 2015 01:25 PM
