Car dies when I "Floor" it
Old May 10, 2006 | 05:08 PM
codeman94's Avatar
ok...so a lot of you know my car, '65, 289 auto coupe, It runs like a top, never had any problems with it, but it has always done something that hasn't really gotten me too upset, but now its getting on my nerves...
So this it what it does...If I am at a stand still, and I floor it, it dies...so that takes any chance of a burn out and throws it in the trash. Also...when I am going about 30 or so, and I floor it, it kinda caughs first, but then HANG ON!!!! Why does it do this?? a carb issue? I want to be able to ruin my brakes by doing burnouts, but I cant cause it dies...Its pretty embarresing if someone sees it happen too...
Old May 10, 2006 | 09:13 PM
Skorch52's Avatar
Sounds like a fuel delivery problem, but I'm not an expert. When you open it up and the air rushes in, there's not enough fuel to keep it running? Maybe the fuel pump isn't working properly or the carb needs to be rebuilt.
Old May 11, 2006 | 06:59 PM
codeman94's Avatar
you dont think its getting ENOUGH fuel? see...I was thinking that it was getting flooded, but what you said makes sense...
Old May 11, 2006 | 07:03 PM
Galaxie's Avatar
I Have Admin Envy
Could be the float level in the carb, either that or something is wrong with the secondaries. It sounds almost as if the secondaries are coming in late, if at all. If the carb is old, maybe the diaphragm is gone.
What kind of carb is it?
Old May 11, 2006 | 07:15 PM
codeman94's Avatar
Edelbrock 500cfm
Old May 12, 2006 | 01:17 PM
Galaxie's Avatar
I Have Admin Envy
Cody,
Has this always happened, or is it recent. It definitely sounds as if there is something wrong with the secondaries coming in. Like I mentioned before, check the condition and level of the float, and see if there is something wrong with the secondaries (my best guess). If the carb has been sitting with dirty gasoline for a long time, I would consdier rebuilding it. I never rebuilt a carb before and managed to do a really good job on the motorcraft carb on my '66 Galaxie. I followed the instructions and it fired up right away.
Old May 12, 2006 | 02:10 PM
codeman94's Avatar
its always done it....ok...I'll check the float. Thanks!
Old Jul 5, 2006 | 01:52 PM
codeman94's Avatar
bump.
everything in the carb seems fine....spoke to may dad about it...he says it could be a timing issue?
Old Jul 5, 2006 | 03:00 PM
Galaxie's Avatar
I Have Admin Envy
just throwing an idea out... check the mechanical and vaccuum advance on the distributor?
Old Jul 7, 2006 | 02:34 PM
codeman94's Avatar
fixed it!!!
Old Jul 11, 2006 | 10:13 AM
Galaxie's Avatar
I Have Admin Envy
was I right?
Old Jul 12, 2006 | 03:09 PM
codeman94's Avatar
yep...it was a bit retarded...but now its pretty just all timed up!...Thanks Steve!
Old Jul 14, 2006 | 02:05 PM
big_block's Avatar
hey codeman what did you we are still rying to burn outs with my sons 65 289 rebuiled 30 over can't do it i think it is the timing we are haveing overheating issues too
jc46002003
Apr 15, 2016 03:00 PM
jim010
31
Sep 14, 2015 08:39 PM
f1-cobra
Aug 1, 2015 08:02 PM
roushcollection
Jul 28, 2015 02:08 PM
dohc97
Jul 19, 2015 07:29 PM
