c4 transmission rebuild questions
Old Jul 22, 2012 | 07:02 PM
live2shred303's Avatar
Ive got a c4 tranny lying around that im gonna rebuild. Ive got a haynes manual for it. Is this the best manual i can get? Or are there better ones available?
Also what position should i lay the transmission out on the table. On its side so i have access to the pan? or flat on its pan?
Old Jul 23, 2012 | 08:10 AM
HOSS429's Avatar
legacy Tms Member
dont do it !!!! .. that is unless you`ve done it many times before .. there are several speciality tools required to do a rebuild .. you will need to lay it in every position imaginable .. and when you do flip it around small check ***** and valves will fall out from every possible spot where you will not know how to put them back ..bit if you just want something to tinker with have fun ....
Old Jul 23, 2012 | 08:11 PM
FMSixtySeven's Avatar
Do c4 transmissions have anything inside of them that looks like a small ball bearing out of a roll cart? Working on the valve body and I found that on the floor next to my head under the car. I did have a rotisserie for a car pop a couple bearings in its wheels a short while ago, so it could be that. Not to thread jack or anything, it just pertains to the conversation.
Old Jul 24, 2012 | 05:53 AM
HOSS429's Avatar
legacy Tms Member
in the c4 the round ***** are less than a 1/4 inch round .. i`ll have to study a bit more as i have`nt been inside one in a few years ..
Old Jul 24, 2012 | 06:25 AM
What are the round metal ***** for?
Old Jul 24, 2012 | 08:06 AM
HOSS429's Avatar
legacy Tms Member
check valves/***** ... they allow fluid to travel in one direction in a particular function of the trans then they block flow in another function .. such as going from foward gears to reverse .. but as i say it`s been a long time since iv`e opened up a c4 .. soneone esle on here may have better info ...
Old Jul 24, 2012 | 01:16 PM
how should i postition the transmission to pull the valve body, as to not lose any of the check ***** or valves? when is it safe to turn the transmission after installing the valve body? is there something that locks them in?
Old Jul 24, 2012 | 02:19 PM
HOSS429's Avatar
legacy Tms Member
on its back ..
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
MustangConvert11
Sep 30, 2015 08:01 PM
