C4 Shifter pattern
Old Dec 2, 2007 | 07:05 PM
ed3sanders's Avatar
C4 Shifter pattern
I have a early 65 coupe with a c4 auto and it has D 2 1 But I have a friend with the same car and his has a little dot then a big green dot then 1. He said he puts it is the 2nd postion for drive. Can any one tell me about this? Which is right? Is the tranny different?
Thanks Ed
Old Dec 2, 2007 | 07:10 PM
future9er24's Avatar
Do you both have the stock shifter bezel? I've never seen what your friend is talking about.
The tranny is most likely the same, but the shifter thing itself is what seems to be different.
Have you got any pics?
Old Dec 2, 2007 | 07:27 PM
n8rfastback's Avatar
the one with the dot is correct. it was called the "green" gear. supposedly is geared for better traction, in the rain and whatever else.
this is the one you have:
Old Dec 2, 2007 | 07:29 PM
this is the green gear one:
same exact tranny, no differences at all. mine has the green gear indicator, and its a 65
Old Dec 2, 2007 | 07:30 PM
check out this page for other views
http://www.svs.com/zim/mustang/64interior.html
Old Dec 2, 2007 | 07:32 PM
the dot one is your standard drive gear... geared the highest.
1 only has 1 gear in it, and the green gear has 2 gears.
hope that clarify's something up for ya
Old Dec 3, 2007 | 08:49 AM
codeman94's Avatar
hmm....mine isnt green.....wierd....and I have this one.
Old Dec 3, 2007 | 04:11 PM
you have that shifter layout and you dont have the green dot???
Old Dec 3, 2007 | 05:24 PM
Dougxox's Avatar
No wonder it would not shift thought I had tranny problems.
Here is a shot of mine.
Old Dec 3, 2007 | 07:26 PM
yup! i usually run her in the green gear until about 50 mph or so.... then shift it into drive so it will go into that 3rd gear and cruise right along.
Old Dec 4, 2007 | 05:45 AM
codeman94's Avatar
nope...its just an "O"...no green dot in the middle....this green dot busniess is new to me.
I remember this thread about a '65 vert....looks like he doesnt have a green dot in his "O" either....
http://forums.bradbarnett.net/showth...ighlight=shift
Old Dec 6, 2007 | 05:48 AM
Dougxox's Avatar
Maybe yours just faded???
Old May 24, 2008 | 04:57 PM
codeman94's Avatar
ok....so I got the car out for a drive today....and I'll be Damed...it IS GREEN! Very faded, but green nonetheless!....The glare off of the shifter must have kept me from seeing it all these years....WOW...I'm blind...
Old May 24, 2008 | 08:10 PM
im not sure what the shifter bezel without the green gear is for
maybe later years. or a different car...
cause all the literature i have ever read tells about the C4 with the green gear for 65-66 stangs
Old May 26, 2008 | 03:08 PM
kennyg's Avatar
Haven't gotten my '66 out in a while, but here's what I recall about the operation of the 'green dot' transmission. If you put the shifter in the 1st dot after neutral, D in later years, the trans will do a 2-3 shift. But if you put it in the 'green dot' position it will shift 1-2-3. Also, the valve body is different in the 'green dot' C-4 and the later C-4. kennyg
Old Jun 5, 2008 | 07:44 PM
Dougxox's Avatar
maybe a new set of beer goggles?
jim010
Jun 24, 2024 04:23 PM
Jul 8, 2016 08:53 AM
K.A.I.N
Sep 25, 2015 03:27 PM
dbrinkley2008
Sep 9, 2015 07:02 AM
Sep 8, 2015 10:45 AM
