68 C4 to T5 conversion
Old Jun 30, 2013 | 07:33 AM
Dyno68FB's Avatar
I have a 68 FB with a 69 351W that just came out of my donner with a C4 on it. I want a manual and have located a 93 T5 out of a wrecked 5.0. Has anyone done this conversion before. What should I grab from the 5.0 and what do I need to order? Any advice would be appreciated.
Old Jun 30, 2013 | 09:01 AM
HOSS429's Avatar
legacy Tms Member
my 69 has a 5 speed but there are just too many things i fabricated to make it work for me to remember .. i know your most difficult problem will be getting a clutch pedal to work .. whether by cable or lever .. i had to make a clutch pedal for mine to get the cable to work .. i know all this stuff can be bought if you look around a bit .. you will need a straight shift flywheel from your era of engine .. meaning a 351 unit of the late 60`s or early 70`s as i believe they have a different balance in later years .. someone more familiar with this than i will chime in soon .. too many people have done it already ...
Old Jun 30, 2013 | 10:17 AM
houtex's Avatar
A kit. Subtract the transmission, these are the things you'll need, with the exception of the pedals in the car, those you'll have to source/fabricate.
http://www.cjponyparts.com/t5-transm...1969/p/T5CK13/
Two write ups, more if you search google for, specifically "1969 Mustang T5 Conversion".
http://www.mustangmonthly.com/howto/...s/viewall.html
http://www.mustangandfords.com/techa...p/viewall.html
It's a chore. But it's been done and plenty how to's and fab already pre done, if you buy a kit to do it.
Old Jul 4, 2013 | 09:08 PM
BA Mustang's Avatar
You can reuse your driveshaft(might need to be shortened), yoke, and transmission mount. You will need a clutch, flywheel, bellhousing, clutch pedal, transmission crossmember, and a few other misc. parts.
I would recommend a late model bellhousing so that you don't need the adapter plate and then you just use a cable or hydraulic clutch kit.
Old Jul 6, 2013 | 07:24 AM
mustangranch66's Avatar
I used a tremec 3550 5sp. I changed the yoke and used a boss 302 drive shaft. I used all the factory 4spd parts but added a adapter to the 5.0 blow shield. I put a plate in between the trans and the bell housing so I could use the older clutch and pressure plate. Ill try to take a picture and add it later
Old Jul 6, 2013 | 07:25 AM
The yoke is from a 87 5.0
DEPUTY62
Sep 12, 2015 11:12 AM
awoychosky123
'10-14 Exterior Modifications
Aug 18, 2015 08:30 AM
