67 mustang
Old Sep 8, 2012 | 12:26 PM
rui628's Avatar
67 mustang
IRS anyone know what the small round spring and cable at the back of the picture is?
It's in the dash and looks like it might have something to do with the air system maybe?
Old Sep 8, 2012 | 08:55 PM
houtex's Avatar
It is likely a control cable for one of the following items:
1) Hot/cold mix door.
2) Vent/defrost door.
3) Inside/outside air door.
It is also possible it's the one to control the driver's side fresh air vent.
Although, I must admit, I'm basing this on a '66 Mustang's innards, and if the '67 has the integrated A/C, then the doors are probably different overall, but not by a whole lot.
Still... I'm wondering what the heck it's doin' up there in the first place... Looks like it came off, and a PO tucked it away so it wouldn't hang down or something...
Hope that helps!
Old Sep 11, 2012 | 04:21 PM
matcox83's Avatar
Good advice. Try moving all of the HVAC controls and see what makes it move. I have a 66 as well so if there is something else cable controlled, I don't know it either.
Old Sep 11, 2012 | 04:22 PM
matcox83's Avatar
Also agree that it looks like it broke off
Old Sep 11, 2012 | 05:40 PM
matcox83's Avatar
The "spring" fits over the end of a lever that moves a door. The bracket there is supposed to hold the outer part of the cable stationary, then the wire portion inside slides and moves the door it is attached to when you move the control lever on the dash. Bad grammar but I hope it makes sense.
Old Sep 11, 2012 | 06:49 PM
kennyg's Avatar
On 67/68's, the 3 cables are joined together with a plastic molded mounting bracket that attaches to the control assembly.
Old Sep 28, 2012 | 09:19 PM
rui628's Avatar
Thanks for the help.
It does seem to go on the lever for the door to the vents, but very weird I only have one that seems to go across from driver left side to assembler right side.
I have the heater box etc all apart, trying to figure that one out!
Feel way over my head !
Old Sep 29, 2012 | 07:12 AM
FMSixtySeven's Avatar
Don't worry about it! We all feel that way at one point or another. That's what this forum is for!
Jim74656
May 1, 2023 02:15 AM
Ecostang
Nov 3, 2022 08:50 PM
dohc97
Jul 19, 2015 07:29 PM
Jul 17, 2015 05:40 PM
