'65 Gas Gauge Issue
'65 Gas Gauge Issue
My '65 convertible's gas gauge is reading "E" but I thought I had enough gas in the tank so I stoped to fill it (only $8.50 which is like 2 gal in CT). The gauge stayed on "E" and later in the day went to 1/2 tank. What could be the issue the float in the tank? Is this a BIG deal to fix or should I just live with it?
legacy Tms Member
most often times the sending unit in the tank is the culprit ,, but first make sure all connections are good .. rarely does a gas gauge in the dash fail .. it`s not out in the elements ..
Thanks as that is what i thought...funny thing I hit a bump in the road and it went to 1/2 full..then later it went up to 3/4 where it usually will go on a full tank..so maybe it was just a querky thing and eventually it will fully fail
