4 lug to 5 lug
Old Nov 25, 2013 | 01:10 PM
Juggalo586's Avatar
4 lug to 5 lug
Is there a convert version kit for this? Or do I have to replace the whole axle?
Old Nov 25, 2013 | 02:26 PM
mustang-68's Avatar
Yes there is r u going with disc brakes up front and yes u have to replace the rear end and the front u can go with wilwood and summit racing sell some too
Old Dec 1, 2013 | 06:00 PM
Juggalo586's Avatar
Yes I'm going to go with disc brakes when I do the conversion. Sorry it took so long to reply. I've Ben having a battle with my headers. Only have about 3in of space to work with. Can't find headers to fit in the tight spot.
Old Dec 3, 2013 | 11:36 PM
mustang-68's Avatar
What kind of header and what size engine r u putting on
Old Dec 4, 2013 | 05:24 AM
jsimmons's Avatar
I'm pretty sure that on the rear, you only have to change the axles/brakes, but you'd probably be better off having the rear end rebuilt while you're at it.
Old Dec 5, 2013 | 08:23 PM
matcox83's Avatar
You have to change the whole rear end. I'm going to try to adapt 4 lug rear discs from an import this winter. I like to be different. Also gonna try to get my 4.5" wide wheels widened to 6".
Old Dec 10, 2013 | 11:30 PM
RagHead's Avatar
If you have a V8 installed in the car and it was an original I6 you need to change the whole suspension system over to V8 specs. Even if you could find a 4 lug to 5 lug conversion kit the added weight of the V8 would present a safety problem.
Old Dec 11, 2013 | 04:30 PM
matcox83's Avatar
In the front, the only parts that are different are the springs and all steering components including knuckles. Control arms, spring perches, strut rods, sway bar, etc are common. If you're not sure if a part is the same, go online and see if the parts houses specify 6 or 8.
Old Dec 11, 2013 | 06:56 PM
Juggalo586's Avatar
Thanks guys. This was helpful.
Old Dec 15, 2013 | 12:47 PM
Go Pens's Avatar
You will also need 65-66 V8 spindles. I did this to my car last year. Just PM me if you need any thing else.
oldnjguy
Sep 10, 2015 02:39 PM
thndrkttn
Aug 21, 2015 09:57 AM
