Is this a 390?
Old Jun 28, 2004 | 03:01 PM
67gt's Avatar
The car has an S code engine which should be the 390. I am confused because I recently bought a mustang repair manual and the picture of the 390 in the book looks nothing like the engine in the car. It is a 67 gt.
Old Jun 28, 2004 | 03:10 PM
BLAKE's Avatar
The pic isn't working for me. It appears to be HUGE, and I can only see the top inch or so.
Old Jun 28, 2004 | 03:11 PM
67gt's Avatar
sorry im trying to figure it out
Old Jun 28, 2004 | 03:15 PM
67gt's Avatar
ok this should work
Old Jun 28, 2004 | 03:16 PM
67gt's Avatar
and
Old Jun 28, 2004 | 03:19 PM
Jay's Avatar
Jay
What makes you think it's not a 390? Looks like one to me...
Old Jun 28, 2004 | 03:23 PM
BLAKE's Avatar
Yup.
Old Jun 28, 2004 | 04:13 PM
Galaxie's Avatar
I Have Admin Envy
That is an FE block,
which means the engine could be a 352, 390, 410, 428... etc. etc.
There is even a "352" cast on the front of the block even if it is a 390,
the best way to be sure is find the casting numbers (on bottom of block) and de-code them.
There is also a small aluminum tag (at least from the factory) between the ignition coil and intake, that has the displacement stamped on it as well.
Old Jun 28, 2004 | 04:24 PM
6t7 stang's Avatar
looks like a 390 to me
Old Jun 28, 2004 | 04:31 PM
LMan's Avatar
390.......unlucky for you
________
LIVE SEX WEBSHOWS
Old Jun 28, 2004 | 04:51 PM
67gt's Avatar
ok thanks, the one in the book had a duel belt for the fan, and the power steering pump was on the passenger side of the motor.
Also was the clutch fan an option?
Old Jun 28, 2004 | 07:01 PM
GT350Clone's Avatar
Definitely an FE - not reason to believe that it's not a 390. A clutch fan could be standard or could have been added/changed - not really an indicator of anything one way or another. If you saw a picture with a passenger side PS pump, I'd tend to think the editor "flipped" the negative - they are always on the driver's side...
Old Jun 28, 2004 | 08:15 PM
67gt's Avatar
Also what type of gas should it be run on, do I need an additive for the gas?
Old Jun 29, 2004 | 09:16 AM
Gattguy47's Avatar
I have a 390 in my truck. The block looks the same. But my Heads are a little bigger then the ones in that pic. I'm pretty sure my heads are stock. But there prob different Engines. Since mine is in a F-100. 1976.
CiniZter
25
Apr 28, 2016 05:41 PM
kingC95GT
1994-2004 V-8
18
Sep 8, 2008 01:33 PM
mot250
Sep 18, 2007 08:00 AM
