302 not firing on all cylinders
Old May 14, 2019 | 02:40 AM
Dusky's Avatar
Hi guys!
First post here.
We have this mustang for 26 years now, and it has always ran fine.
We've had to replace some things over the years, plugs,wires,.. but it has always been in good condition.
Went on the first trip in a year a few days ago and it started to really really run bad. Sounds like it's only running on 4 cilinders, won't idle.
First thought was a blocked carb but that wasn't the problem ( checked with a different carb, same problem)
Changed the coil and condenser and reset the points => no change.
A bit puzzled here. It has some fresh fuel as well. Can't imagine its something catastrophal either ? Any ideas? Only thing that wasn't changed for a new part is the points, but can't imagine those would go bad in this way?
Thanks in advance
Old May 14, 2019 | 04:36 AM
Paris MkVI's Avatar
First thing I would do next is pull the plugs and look them over; see if any are fouled or indicate another issue. Also check vacuum hoses for failures.
Old May 15, 2019 | 07:05 AM
and while you have the plugs out do a compression check.
prpwall
Feb 24, 2012 03:45 PM
GTStang01
Jul 12, 2007 12:58 PM
Every_Mn
Apr 10, 2007 11:54 AM
tacbear
Dec 30, 2006 08:54 PM
RPM
14
Dec 21, 2006 06:31 PM
