289 engine help
I've recently started working on my '68 coupe again and I would like to get her running in time for spring and summer. I'm not doing anything major until I graduate college in May, but like I said I just want it running so I can drive it.
I've got a coolant leak between the block and the timing chain plate. I've already dissassembled the front of the engine and it looks like I have to drop the oil pan to pull the plate off. Is this correct? I'm wondering if this is possible with the engine in the car? Would it be 10x easier just to buy an engine stand to do this with the motor out of the car?
Also, my pass. quarter window will not roll up, is it hard to remove and fix?
I'll post pics later. Thanks.
For the passenger side window all u have to do is take out the rear seats and theres a rubber moulding on the side nearest to the door u have to take off...take off the window handle and it should come off...
You do not have to remove the pan,but you do have to remove the front pan bolts as they go into the timing cover.Can be done while in the car,just take your time.Be sure to put sealer on the water pump bolts as some of them go into the water passages and will leak at the bolt head.
Here of some pics, in the garage now and when I was in high school in 2001
[attachmentid=42360]
[attachmentid=42361]
Here is the tired old 289. It has a 67 steering wheel, taillight bezels and fender letters, and it had a 67 grille when I bought it. But everything will be 68 when I restore it.
[attachmentid=42362] then
[attachmentid=42363] now
If you are going to remove the water pump and timing cover, I recommend buying new bolts for the water pump (they come in a kit), using quality sealant with the gasket, and replace the hoses and clamps while you are in there.
