289 or 302
Old Oct 14, 2011 | 09:20 AM
my65's Avatar
289 or 302
My wife and I bought a 65 coupe a couple days ago. The place where we bought said it had a 302 in it. Other than looking on the block for the code is there an easy way to see if it is a 302 or maybe if it's a 289? Any help would be great.
Old Oct 14, 2011 | 09:43 AM
AlsCobra's Avatar
A Man Just Needs Some....
Not sure but the 302 wasn't till mid 68 in the mustang.
Old Oct 14, 2011 | 09:56 AM
my65's Avatar
The original motor has been replaced. I checked the vin and it came with I6.
Old Oct 14, 2011 | 10:10 AM
HOSS429's Avatar
legacy Tms Member
there usually is a little metal tag on one of the carb bolts .. it will say what it is if it has`nt been altered ..
Old Oct 14, 2011 | 10:27 AM
aston70's Avatar
Saw this on another forum...
Look at the crankshaft for a stamped number - 1M = 2.87 stroke (289) and 2M = 3.00 stroke (302). As mentioned, the rods need to match the crank unless you've got non-standard pistons. A rod # starting with C3 is a 289 rod, C8=302 rod.
source:
http://www.stangnet.com/mustang-foru...-try-post.html
Also, if it was originally an I6, I believe those had a 4 bolt wheel lug pattern. That may need to be upgraded if not already as those spindles may be too weak to be holding up a V8.
Old Oct 14, 2011 | 10:31 AM
HOSS429's Avatar
legacy Tms Member
and all cosmetic and performance bolts on will fit either engine if that is your concern
Old Oct 14, 2011 | 11:39 AM
my65's Avatar
Thanks for your help
Old Oct 14, 2011 | 01:45 PM
aston70's Avatar
Also, I don't know how accurate this is, but I think the '65 289s had a black block with gold valve covers while the later 302 had everything blue. Of course only if that's the original paint. I know someone who painted their 65 289 covers blue... So that's not a guarantee.
Old Oct 14, 2011 | 02:59 PM
my65's Avatar
It does have a blue block
Old Oct 14, 2011 | 06:52 PM
Falchion's Avatar
You probably have a 302 like mine is. Not really a bad thing.
The 65 didn't have a VIN on the block so there isn't really a "numbers matching" 65 Mustang........
Raynier Leonardo
'10-14 Exterior Modifications
27
Mar 2, 2017 12:08 AM
Mustang65bob
Sep 21, 2015 11:30 AM
Evil_Capri
Sep 11, 2015 08:39 AM
