24 inch radiator in a 65 Mustang
Old Jul 1, 2010 | 06:18 PM
Falchion's Avatar
I'm having a 24 inch radiator put into my 65 Mustang in the place of the orginal 17 inch wide one. The car gets hot in traffic since it isn't getting enough air flow through the AC condenser, and the radiator. I'm hoping that going to the wider radiator will help with that. I'll post some more pics when I get the car back next week. (Bottom two pics)
Here's what one called by the name of "Mustang Steve" did to his 65 Mustang. I think it looks really good!
Attached Thumbnails 24 inch radiator in a 65 Mustang-65-mustang-24-inchradiator-3.jpg   24 inch radiator in a 65 Mustang-65-mustang-24-inchradiator-2.jpg
Old Jul 1, 2010 | 08:43 PM
HEADACHEZ's Avatar
Looks good! did it help with cooling issues?
Old Jul 2, 2010 | 06:55 AM
Falchion's Avatar
I haven't gotten it back yet. Those pics are ones taken by the shop owner. They're still working on the rear end. They should get it done by next week some time.
Here's the condenser they're going to put in it. It's the one that doesn't block the air as much. Seemed to work a lot better then the one I had on there.
http://www.oldairproducts.com/catalo...roducts_id=168
Condenser, SuperKool, 16x21x1-Overall
MORE DATA
Choosing a condenser for your vehicle is one of the most critical pieces of your air conditioning system. If the fin pack is too dense, it will restrict air flow to the radiator, leading to overheating issues. If the fin density is too loose, high head pressures will arise, creating a poor quality of refrigerant, contributing to higher louver temperatures in the interior of your vehicle. The Super Kool Condenser Technology was developed to resolve these problems. This condenser was designed specifically to increase heat transfer for lower head pressure during idle situations. The advanced cross flow tube design allows the spacing of the fin to be manufactured at 14 fins per inch, while our competitors use a denser fin such as 16 and 18 fins per inch. Super Kool Condensers will allow more cubic feet of air to pass through the condenser and give the radiator the volume of air it needs to operated properly. With it's all aluminum, heavy duty construction, the Super Kool Condenser is one of the highest performing, durable condensers available in today's automotive market.
Old Jul 8, 2010 | 07:57 PM
Falchion's Avatar
OK, I got my 65 Coupe back with the 24 inch radiator in it. They did a good job over at Mid Cities Mustangs, it looks dead stock if you didn't already know your way around the engine bay of a 65.
It wasn't very hot today so I wasn't able to give it a good test, but if it doesn't work I don't know what else to do.
Anyways, here's some pics!
Old Jul 8, 2010 | 08:31 PM
HEADACHEZ's Avatar
Lookin good
Old Jul 9, 2010 | 08:00 AM
Falchion's Avatar
Thanks!
Old Jul 11, 2010 | 03:02 PM
Falchion's Avatar
Just back from a test drive. The car still gets hot! It's not as bad as it was was, but with the AC on the temp still creeps up at a stop light.....
It was doing pretty well at first. I took it to the car wash and it didn't get over 190 even at a stop light. But, I think the heat gets built up in the engine compartment because it has no place to go.
Not sure what else to do. I have a different shroud on order that should fit tighter around the fan, but other then that I'm not sure what else to do.
Old Jul 11, 2010 | 03:53 PM
HEADACHEZ's Avatar
Try some wetter water you could pick some up for like $8 - $9 at your local auto parts store just open the cap and pour it in. You might have to drain a small amount of coolant/water from the radiator first.
Old Jul 11, 2010 | 05:15 PM
Falchion's Avatar
Yeah, I've got some of that coming along with the new fan shroud. I'm not sure it will help.....
Old Jul 26, 2010 | 03:17 PM
Falchion's Avatar
I'm having a custom radiator built by Mattson Radiators. It's going to be a cross flow design.
They also make a cross flow for the 65-66 Mustang. See seconfd picture.
http://mattsonsradiator.com/products...ors/index.html
Attached Thumbnails 24 inch radiator in a 65 Mustang-65-crossflow-radiator.jpg   24 inch radiator in a 65 Mustang-65-crossflow-radiator-2.jpg
Old Aug 30, 2010 | 06:42 PM
Dougxox's Avatar
$$$$ gee can I borrow your check book for a while??? LOL
Old Aug 31, 2010 | 08:04 AM
Falchion's Avatar
Not really that much. $895, which is cheap compared to what I have spent already on this problem.
Ecostang
Nov 3, 2022 08:50 PM
RRRoamer
Jan 19, 2017 05:27 PM
salazamk
Aug 22, 2015 02:19 PM
gioinos
Jul 11, 2015 12:28 PM
