Rocker Panel Repair/Replacement
Does anyone have a guide and/or experience on this? I was leaving a parking lot and left my trunk open so I pulled over to close it. When I did and was pulling back into the road, I clipped the edge of a parking block right under the front passenger seat. It just scuffed the panel a bit in a low visibility area so I wasn't going to replace it BUT it did pull it loose from about half of the clips holding it on. I was wondering if I need to buy new clips (if so, anyone know the part #?) or if they can just be popped back on. And is there a certain way to remove the rocker panel?
It's actually got quite a few clips running the length of the thing. I found Late Model Restoration sells a pack of all the needed hardware. The scuffs are very superficial and all on the very bottom of the panel so I'll use touch up paint at most...
Evil_Capri
9/11/15 08:39 AM
