What size rear tires??
My car has a Boss Mani, steeda cai, and steeda tune. Installed steeda billet LCA's with BMR relocation brackets and even with them set in the lowest hole (for the most traction) the car is still roasting the tires through first and second gears. Car is a track pack so it has 3.73s And stock p zeros. I love the track pack wheels and have an extra set so I am going to send two to weldcraft to get widened to 19x10 or 19x10.5. Will a 295 tire do the trick. Can't leave the control arms at their lowest setting for traction because I don't like the way the rear feels when handling hard.
Having the stock wheels widened may give you some options as to where the "widening" is added...so I'd say that the answer to your question is YES.
I can also promise you that even though the stock Pirellis are pretty good for an OEM tire, a more dedicated performance tire will help a lot.
I don't think the American Muscle ones are the same color as the OEM ones. If they were, I'd have to get a set. Hopefully they come out with some the same finish as stock ones.
My advice would be go no wider than 295 or 305.
John
The offset on my rear 20x11 Steeda Spiders is 59mm. Steeda runs 315 wide Nitto Invo's with no issues, or at least I'm told no issues. I put 315 Michelin Pilot Super Sports on mine and get a very slight rub at heavy jounce and extreme off camber driveway approaches. I think the shoulder on the Pilots might be slightly more square should than the Nitto's and what's causing the issue. I might be able to adjust that out with the panhard bar but haven't tried yet. Guess that should tell you how bad the issue really is!
John
John
I run 305's in the rear, but I still lose grip 1st, 2nd, and partial 3rd. When the tires are heated up, they're better at gripping, but still get overpowered. I might try Mickey Thompsons next time.
https://themustangsource.com/forums/...-strip-537073/
Detroit Steel
7/28/15 12:53 PM
