Notices
Sponsored By:
Sponsored By:
Creaking sound from front when driving over speed humps
Old 10/20/14, 02:35 AM
pauljohnpena's Avatar
I drive a 2014 Mustang GT Premium and I noticed that there's this creaking sound (and feel) when driving over speed humps (small or big ones). I wonder if this is normal.
Let me know if you've experienced this and what the fix could be so at least I could also tell the dealership when I go on a check up.
Thank you
Old 10/20/14, 12:51 PM
Legacy Tms Member
junkman9096's Avatar
Yes, at least to me its normal action of the shocks doing their thing. Likely something with the rebound control. It just an idiosyncrasy. Now, if you're hitting speed bumps at 60mph the noise could be indicative of something else. :-)
Old 10/20/14, 01:00 PM
Jazzman442's Avatar
On my 2014 I do not have this issue. On my 2006 pony I have the same thing. not sure what it is.
Old 10/20/14, 03:35 PM
Darth Paul's Avatar
I just had the front control arms replaced under warranty on our '13 GT. This is a KNOWN ISSUE at Ford. It is not supposed to creak going over speed bumps!
Old 10/20/14, 04:29 PM
Jazzman442's Avatar
Did they say what was causing the issue?
Old 10/20/14, 07:40 PM
Thanks! I already included it in the list of things for them to check. I'm just about to do the first 1000 KMs PMS check up. When did you start hearing these sounds anyway?
Old 10/21/14, 06:14 AM
Darth Paul's Avatar
Our car is a used '13 and we noticed it the first time we went over a speed bump. Naturally, we didn't go over any during the test drive.
Old 10/21/14, 11:05 AM
Yes, we didn't go over any, too, during the test drive. That's something to really check. Wonder what the fix is.
Old 10/21/14, 11:30 AM
Haha, no of course not. I always go slow on those speed bumps!
Old 10/22/14, 09:07 AM
FordService's Avatar
Thank you
Hello again, pauljohnpena! Since you’re in the Philippines, I recommend calling the Ford Group Phillipines, Inc. at +63 (49) 541 5000 for assistance.
Also, I know we’ve made arrangements with the Overseas Military Sales Corporation (OMSC) to assist with service-related issues. OMSC can help you find a participating service center, which should be able to assist you with the key. Please contact them at 1-800-669-6183 or 9-011-49-6173-704-256. I hope this helps.
Have you addressed this with your Ford Dealer, Darth Paul?
Deysha
Old 10/22/14, 10:02 AM
mustang8918's Avatar
pauljohnpena,
If you check under the Warranty and Service Issue section you'll find your answer. I just had my lower control arms replaced because of that noise which is from the bushings and my '14 GT turned one month old yesterday. The TSB to reference is 12-8-24 (GRUNT/CREAK/CHIRP/SQUEAK NOISE FROM THE FRONT LOWER CONTROL ARM OVER BUMPS).
Old 10/23/14, 07:21 AM
Darth Paul's Avatar
Originally Posted by FordService
Have you addressed this with your Ford Dealer, Darth Paul? Deysha
Yep, had it taken care of last week.
Old 10/23/14, 08:52 AM
Great! Thanks for the update, Darth Paul!
Deysha
Old 10/24/14, 10:42 AM
Originally Posted by mustang8918
pauljohnpena, If you check under the Warranty and Service Issue section you'll find your answer. I just had my lower control arms replaced because of that noise which is from the bushings and my '14 GT turned one month old yesterday. The TSB to reference is 12-8-24 (GRUNT/CREAK/CHIRP/SQUEAK NOISE FROM THE FRONT LOWER CONTROL ARM OVER BUMPS).
Thanks so much. Yeah am gonna bring this up with them. How long did hey take to fix yours? Did they have to 'wait' for parts?
Old 10/24/14, 10:44 AM
Hello again, pauljohnpena! Since you’re in the Philippines, I recommend calling the Ford Group Phillipines, Inc. at +63 (49) 541 5000 for assistance. Also, I know we’ve made arrangements with the Overseas Military Sales Corporation (OMSC) to assist with service-related issues. OMSC can help you find a participating service center, which should be able to assist you with the key. Please contact them at 1-800-669-6183 or 9-011-49-6173-704-256. I hope this helps. Have you addressed this with your Ford Dealer, Darth Paul? Deysha
Got it. Thanks
Old 10/24/14, 07:10 PM
HizliBullet's Avatar
pauljohnpena,
theres a new one actually, TSB 13-09-03, my friend did it, heres the whole work order or parts needed to be replaced
under section C) CHECK AND REPORT FOR SQUEAK NOISE WHEN GOING OVER BUMPS, read below for the TSB no.
Attached Thumbnails Creaking sound from front when driving over speed humps-mmexport1414190284040.jpg
Old 10/25/14, 04:26 AM
Reminisce's Avatar
Get this done ASAP. I thought it was normal on my 12 GT and I put heavy miles on it. After about 20k miles i noticed my tires were wearing very unevenly on the outer tread. I took it in to Ford and they replaced the control arms and did something else (can't find the repair sheet). Squeaking has been gone since. But my tires got worse. When I got a new set of tires put on, the mechanic mentioned how way off my alignment was.
When you get this done, i strongly advise getting your front alignment checked as well.
Old 10/25/14, 04:04 PM
i did not know that, i got brembo package that came with pirelli pzero, dont want premature wear on those
Old 10/27/14, 08:35 AM
Got it. Thanks
You're welcome, pauljohnpena!
Deysha
Old 10/28/14, 11:21 PM
I'll have to check and see if they replaced mine with the shields.
Quick Reply: Creaking sound from front when driving over speed humps
