HOW TO: Remove Air Bag & Steering Wheel
Old Feb 2, 2008 | 08:11 PM
StangNut's Avatar
Since I'm pulling out my wood steering wheel before I sell my car, I decided to do a write-up (with pics) on the removal. Some people won't agree with all the steps I'm listing, but this is the way I did it. I'm not a mechanic so take that for what it's worth. This is just a guide. You should use Ford's service manual to ensure you do this correctly. Think about it... messing with an airbag can be dangerous.
1. Loosen the 5/16" nut and disconnect the negative lead of the battery.
2. Remove the access door from the passenger side kick panel.
3. Remove the cover from the Smart Junction Box.
- There are tabs/clips on the front (left side in the pic) and back sides that hold the cover in place.
4. Pull the airbag fuse. F2-17
5. Pop out the little covers on the back sides of the left & right spokes.
6. Remove the 5/16" bolt on each side.
- These are the bolts that actually hold the airbag in place.
7. Pull the airbag away from the wheel.
- See the black metal tabs with a hole in each one? That's where the bolts were.
- That's all that's holding the airbag in place so once you remove the bolts you can just pull it out.
8. Disconnect the clockspring electrical connectors. (the wires with the yellow sleeves on them)
- Squeeze the tabs on the sides of the connectors to release them.
Airbag removed:
NOTE: You can skip steps 9-14 then simply unplug this single connector for the cruise, horn lead and horn ground if you'd rather remove the other parts after the wheel is off.
(you'll probably have to swap several parts from your old wheel to your new one)
I couldn't get the connector out even though I had it out for the initial swap 2 years ago.
[IMG] [/IMG]
(EDIT 9/15/2016: There should be a picture here showing the connector I'm referring to but after 8 1/2 years, I've forgotten what pictures I used before or which connector it is. Sorry!)
9. Remove the left & right inserts by pulling on the edges. (sides or end)
- It was easiest for me to pull on the ends instead of the sides simply because the wood wheel has more of a gap there than the leather one.
The inserts (and the cruise control buttons) have plastic tabs that are in tight holes in the thick black rubber underneath.
The tabs don't "snap" into anything so they'll just slowly come out of the rubber.
[IMG] [/IMG]
(EDIT 9/15/2016: Again there should be a picture here.)
10. Remove the cruise control buttons the same way. They also have tabs going into the rubber.
11. Remove the three T30 torx bolts from the horn plate. (red circles)
12. Pull the dark red connector off of the tab on the horn plate. (green circle)
13. Remove the T20 torx screw in the pink connector. (red circle)
14. Pull the black cruise control wires from the white retainers. (green circles)
15. Remove the 15/16" steering wheel bolt from the center of the wheel.
16. Remove the steering wheel.
If anyone has any questions, corrections, or something they think should be added, please let me know.
Thanks to garyb900 for the pic of the SJB fuse diagram and to TacoBill for all the great write-ups he's done.
EDIT 9/15/2016: It took a lot longer than I expected to get the pictures back up and I was in a hurry so I apologize if this "How To" isn't as good as it was the first time.
Old Feb 3, 2008 | 06:44 AM
Louie's Avatar
Thanks for the "how-to"!
One question: what's the best way to enure the new steering wheel is correctly centered? Are there any markings to show you the "straight ahead" position?
Old Feb 3, 2008 | 12:43 PM
StangNut's Avatar
It only goes on one way so that wouldn't be a problem.
The electrical plug for the airbag wires lines up in an opening in the wheel and the bolt centers it up.
Old Feb 4, 2008 | 06:32 PM
Little Black Pony's Avatar
Hey StangNut,
Great write up! the whole procedure looks pretty straight forward.
BTW, why did you need to remove your cruise control buttons?
Old Feb 5, 2008 | 08:05 AM
Great write-up Jason.
Mind if I add this to the Hotlinks sticky?
Oh yeah, you get one of these!
Old Feb 5, 2008 | 09:36 AM
StangNut's Avatar
Originally Posted by Little Black Pony
Hey StangNut,
The wires run through the center of the wheel so the cruise either had to be removed or unplugged. It was easier to pop out the buttons than unplug them.
Old Feb 5, 2008 | 09:37 AM
StangNut's Avatar
Thanks, Bill. Coming from the master, that's a quite a compliment. I'd be honored to have it in the Hotlinks Sticky.
Old Feb 5, 2008 | 02:47 PM
You give me too much credit!
Added to sticky!
Old Feb 14, 2008 | 09:43 PM
StangNut's Avatar
Hey, Bill. Ever thought about making your own website just for write-ups?
Here's a Jeep example:
http://www.stu-offroad.com/index.asp
I'm not sure if he gets his stuff and only posts on one website (www.jeepsunlimited.com) or not, but his site is well known on all the Jeep forums I've been to.
Old Aug 11, 2012 | 06:48 PM
Barricade's Avatar
Ok...Im about to shoot my car. I cant get the goofy lid off.
Where are these tabs? Im hitting and pushing on everything and its
not budging.
Old Aug 13, 2012 | 06:08 AM
StangNut's Avatar
Wish I could help. I don't have that Mustang anymore. Here's a bump for you. Hopefully someone will go out and take a look at theirs.
Old Aug 13, 2012 | 06:17 AM
Barricade's Avatar
I removed the whole side panel (which is easy to do)
and saw it. Its on both sides and is a catch. Just pull
back on it.
Old Aug 18, 2012 | 08:17 PM
05RedGT's Avatar
Great write up! I replaced my steering wheel today with a Grant wheel from Summit Racing (picked it up on clearance for less than $120). The hardest part was getting the cover off the SJB.
Attached Thumbnails HOW TO: Remove Air Bag & Steering Wheel-img_1749.jpg
Old Jan 12, 2015 | 11:29 AM
StangNut's Avatar
If anyone needs the pics re-uploaded in the first post let me know.
Old Sep 13, 2016 | 01:49 PM
mustangsally_'s Avatar
I cant see any of the pictures.
Old Sep 13, 2016 | 01:50 PM
Just got a GT Wheel for $20 and looking to switch out my stock V6 all black wheel.
help?
Old Sep 13, 2016 | 02:53 PM
StangNut's Avatar
I'll try to get the pictures back up this week. If you don't see them by the weekend, send me a PM to remind me.
Old Apr 9, 2018 | 05:42 PM
Jcreek79's Avatar
Do we have to remove the airbag in order to remove the steering wheel spoke covers?
Old Apr 9, 2018 | 08:06 PM
houtex's Avatar
Nope. See the other thread.
hpb50
Sep 27, 2023 03:03 PM
poldrv
Aug 18, 2015 06:42 AM
tdf017
Aug 5, 2015 10:13 AM
Vader99
Jul 19, 2015 08:19 PM
