BMR Swaybar Delete Kit Install
Old Feb 11, 2007 | 10:49 AM
89Trooper's Avatar
I've had my swaybar off for quite awhile now, so I decided to break down and get the BMR Swaybar Delete kit that replaces the heavy stock radiator support. For those who do not know, the stock support also has to be able to take the forces acting on it from the swaybar. So, if the swaybar is removed, this big, heavy support isn't needed any more. After removing the swaybar and replacing the support, there is a weight savings of almost 30 lbs.
First, I jacked up the nose and put the car safely on jack stands. If you are removing the swaybar you'll probably want to take off the front tires for more access, but this isn't necessary if you are just changing the radiator support.
SWAYBAR REMOVAL
I didn't take any pictures when I removed the swaybar, but it's very easy. Basically, there are six nuts that have to be removed. Four of them are on the radiator support shown here:
This also shows the difference between the two supports.
The other two nuts that have to be removed hold the swaybar end links to the strut assemblies:
Thank you, TacoBill, for the pic!
After those six nuts are removed, the swaybar and the end links will come right off the car.
PLASTIC PROTECTOR REMOVAL
Seven little bolts must be removed and this piece will drop right down. Close your eyes if you are under this when you pull it down... a lot of trapped dirt will probably come down as well.
STOCK RADIATOR SUPPORT REMOVAL
The first thing that should be done is to remove everything that is connected to the stock support. This is best shown in this picture:
The yellow circles show the clips that hold the brake line. Just pop the brake line out of the clips. The blue circle shows where the A/C line bracket attaches. Remove the nut and then remove the bracket from the stud. There is also a wire tie holding the power steering line shown in this picture:
It's kinda blurry, but I just cut the wire tie. I'm not sure why it's even there.
Next, loosen the four nuts that attach the radiator support to the frame. Do not remove them at this time because the radiator will come right down with the support.
This is what happens when you start to loosen the four nuts:
The top radiator supports prevent the radiator from going up, left, right, forward, and backwards... but not down, so the radiator has to be supported:
I just used a jackstand. It worked perfectly.
Now that the radiator is supported, you can fully remove the four nuts and drop the radiator support down and out from under the car.
PARTS SWAP
There's nothing much to do here... just move the rubber over from the stock support over to the BMR support:
BMR SUPPORT INSTALLATION
Couldn't be easier. Line up the four studs and make sure the radiator is in the two rubber pieces, and mount it back to the car:
After the nuts are started, you can get the jack stand out of the way that is supporting the radiator. The torque for these four nuts is 85 lb/ft.
FINISHING UP
For the price, you would think they would include wire ties to re-connect the plastic piece to the new support, but they don't. Here are the extra things I did:
I used a thick wire tie to connect the A/C line bracket to the BMR support. It was held on by that nut to the stock radiator support, but this holds it just as well.
Re-install the four bolts that hold the plastic piece to the bumper. The rear is held to the BMR support with three wire ties.
You'll find this rubber isolator on the brake line toward the passenger side of the car. The brake line ran close to the stock support, and this kept it from hitting. It's not needed any more, so I moved it to the center of the brake line where it now comes close to the BMR support. The center wire tie that hold the plastic piece to the BMR support also goes around the brake line. I could have pulled the brake line tight against the support, but I didn't want the brake line to eventually wear through from vibration, so that's why I put that rubber isolator there. (No, I didn't bend the brake line like that... that's how it is.)
Here's a shot of the three wire ties used to hold the plastic piece. They hold it just as good as the 3 little bolts did.
WEIGHT DIFFERENCE BETWEEN THE TWO SUPPORTS?
This should explain it perfectly:
Old Feb 11, 2007 | 10:07 PM
scramblr's Avatar
Excellent write up Man. Good tip on the rubber piece and the brake line too. Thank a lot!!!!
Old Feb 12, 2007 | 07:58 AM
Very nice write-up, Tom!
Hope you don't mind that I added this to my Hotlinks sticky.
Old Feb 12, 2007 | 09:44 AM
DavidM's Avatar
89Trooper, How does the car handle now since deleting the swaybar? I have been thinking of doing this mod as well and am curious about the difference in ride quality.
Old Feb 12, 2007 | 11:16 AM
89Trooper's Avatar
Thanks! And, not at all...
Before spending the money on BMR's brace, I left the swaybar off for over a month and felt absolutely no difference in handling. Curves feel the same and I don't feel any extra sway.
As far as ride quality, it actually improves since each side is now truely an independant suspension. Before, if one wheel hit a bump, that wheel raised up and it torqued the swaybar and forces were transferred to the frame - and then to the driver. Now, each side acts on it's own and the ride feels better.
Old Feb 12, 2007 | 11:45 AM
hawgman's Avatar
Nice write up. Only comment I have is UPR has the same piece for 1/2 the price of BMR http://www.uprproducts.com/shopping/shopexd.asp?id=1121
Old Feb 12, 2007 | 11:51 AM
vsop's Avatar
I wish they would make a chromemoly tubular rad support that allowed you to keep the swaybar for street/track use
Old Feb 12, 2007 | 12:18 PM
89Trooper's Avatar
Now you tell me!
Yeah, that's Granatelli's support... and a great price!
Old Feb 12, 2007 | 12:19 PM
89Trooper's Avatar
I don't think it would be able to take the forces acting on it from the swaybar.
Old Feb 12, 2007 | 12:22 PM
vsop's Avatar
If stamped steel can handle it a properly designed Chromemoly piece will be able to and more.. Chromemoly tubing is way stronger then stamped steel and will save weight.
Old Feb 12, 2007 | 12:30 PM
scramblr's Avatar
I took off my sway bar for about a month to try it out and I couldn't feel the difference...and I drive pretty hard and cut some corners. Decided to get the Rad support as well. Got the GMS one from UPR for $79.99 shipped.
Old Feb 12, 2007 | 01:46 PM
89Trooper's Avatar
Wouldn't that have to be stronger and heavier? These pieces are very light and I don't think would hold up to the swaybar forces. If you made the tubing stronger and heavier, wouldn't it just defeat the purpose of changing it? I know you said it would be lighter, but how much lighter? Plus there would have to be additional plates added to mount the swaybar.
Just ordered it today? Let us know how it compares to the BMR install.
Old Feb 12, 2007 | 02:01 PM
vsop's Avatar
No.. Chromemoly tubing is much stronger then Mild steel tubing and is lighter in that it requires a smaller or thinner wall to be just as strong.
Notice how the stock K member is stamped steel and the tubular units are tubular and can still save 20lbs off stock and those use mild steel.
Using chromemoly is limited because of the added cost, but its the best.
Most 10 point roll cages you will see are made out of chromemoly because it allows them to use a lighter tubing yet be just as strong as the bigger/heavier mild steel tubing.
Old Feb 12, 2007 | 02:04 PM
89Trooper's Avatar
OIC... then you're right... someone should make that option available.
Old Feb 12, 2007 | 02:27 PM
Arrow's Avatar
Do you always make your kids fix your car? Make'n that poor child take apart yer front-end while you sit back and have a beer. Have you no shame?
Nice tut, Trooper. I have no interest in doing this, but good information is always good!
Old Feb 12, 2007 | 02:41 PM
LEO_06GT's Avatar
Now you tell me!
Ouch considering GMS probably stole BMR's design. I might just have to get one for that price.
Old Feb 12, 2007 | 02:44 PM
89Trooper's Avatar
Having her cut that hole in my hood was a real *****!
and... thanks!
DavidM's Avatar
Good to hear about the handling diffs I feel better doing the mod now having read this thread.
Originally Posted by LEO_06GT
Ouch considering GMS probably stole BMR's design...
I'm going to leave that one alone.
Old Feb 12, 2007 | 02:56 PM
neil07gt's Avatar
It seems like you would get alot more understeer without a front bar. I'm curious enough to try it myself.
