NastytGT: Roush TVS @ 524 rwhp
Old Oct 19, 2009 | 08:36 PM
NastyStang113's Avatar
I finally got one of VMP's new pulleys for the Roush TVS. It allows the use of the stock crank pulley and water pump pulley. No more running the Steeda UDPs which means no more broken water pump pulleys. I broke two in the course of a couple months. Apparently they can't take the load and abuse. I'm currently running a 3.25" blower pulley, stock crank pulley, stock water pump pulley, and a 90mm idler directly below the blower. The pulley uses a press in hub and than the pulley bolts to the hub. So, pulleys can be swapped fairly easy.
I suspect due to belt wear and how much dust it was putting off that it was probably slipping quite a bit with such a small blower and crank pulley. Another good thing about the pulley is that I really can't see the belt coming off of it. This set-up should also create more belt wrap so there are no issues of it slipping currently. I'm going to be putting a brand new belt on it and watch how it wears very closely to see if there was a problem previously. I'll post in a couple of weeks about how that turns out. I'm very happy with the set-up and can't wait to try some more things out in the future!
Steeda Water Pump Pulley Damage
First time:
Second Time:
3.25" Pulley & Hub.
VMP Pulley Tool I used to remove the 2.65" pulley and install the new 3.25" pulley:
Hub Installation:
Previous Set-Up Dyno - 506 rwhp / 475 rwtq @ 10 psi:
New Set-Up Dyno - 524 rwhp / 502 rwtq @ 11 psi:
Old Oct 21, 2009 | 01:35 PM
ChinoMach1's Avatar
God I love your car!! Justin is definitely an amazing tuner!
Old Oct 21, 2009 | 01:39 PM
Evil_Capri's Avatar
Old Oct 21, 2009 | 11:36 PM
EAGLE 5's Avatar
You are everywhere....
Old Oct 22, 2009 | 06:34 AM
EagleStroker's Avatar
I don't do trannies
or rear-ends anymore!
Guess I should of seen this before I asked this:
https://themustangsource.com/showpos...5&postcount=21
Looks great man, I knew something was different!
Old Oct 22, 2009 | 03:50 PM
06GT's Avatar
Wow, very cool. You running forged internals?
Also--look into the GT500 belt tensioner from Steeda. This solved problems with belt slippage/breakage on our 427R Track Pak racers.
Old Oct 22, 2009 | 04:42 PM
Nope, factory longblock. The Roush TVS includes a upgraded tensioner.
Old Oct 23, 2009 | 07:31 AM
69Mach1-409's Avatar
Very nice!
Old Oct 23, 2009 | 02:12 PM
chad05gt's Avatar
did ya get that monster to the track yet!
Old Oct 23, 2009 | 04:03 PM
Nope, just got my transmission/shifter/clutch issue fixed. However, I'm not making it to the track until the new year. I'll post a picture of the Nitto NT555Rs in a little bit ... Raped ...
Old Oct 24, 2009 | 09:39 AM
chad05gt's Avatar
Yup, thats where a set of cheap 15" jegs w/ cheap ET STREETS will SAVE $! LOL!
Old Oct 27, 2009 | 03:17 PM
ROUSH STAGE II's Avatar
Good job bro!
Old Oct 28, 2009 | 04:52 PM
Tsbird1994's Avatar
Does jegs make a set that fits our cars? (Fronts and Rears?)
Old Oct 28, 2009 | 05:11 PM
tom281's Avatar
Nice setup, thanks for posting the info.
Old Oct 28, 2009 | 05:22 PM
MARZ's Avatar
Swamp Donkey Aficionado
Man, that's a lot of power and torque! Are you still running the stock fuel pump?
Old Oct 29, 2009 | 11:35 PM
WuTimeUT's Avatar
wow your car looks great.... what rim/tire setup are you running? the stance looks great
Old Nov 2, 2009 | 09:01 AM
Nope. I was able to get around 463 rwhp at 8 lbs with the stock fuel pump. It had a small amount of cushion but it's not ideal by any means. If you want to do something like that than you better be using a badass tuner who has the car in front of him. It might or might not work. Currently, I'm running the GT500 fuel system.
Springs: Steeda Sport Springs
20x8.5" American Racing Rogues - Nitto NT555 255/35/20
20x10" American Racing Rogues - Nitto NT555R 305/35/20s
Old Nov 16, 2009 | 02:20 PM
fiverrivers's Avatar
have you run your car against a gt500 and if so what was the result.
Old Nov 18, 2009 | 08:55 PM
2007+ (Not including the 2010) GT500s only make ~440-450 rwhp stock, the car weighs a lot more, and I'm running drag radials. I don't think it's a fair comparison.
Old Nov 18, 2009 | 08:58 PM
That is the definition of a NASTY stang.
