Hot Rod Garage Walks Us Through Brake Swap and Lowering Kit Install
By -
hot rod garage mustang
One of the most appealing things about new Mustangs is that they perform great and look amazing without costing you an arm and a leg. Thanks to a huge aftermarket presence, it’s also easy to make them even faster and even better looking, all without breaking the bank.
In the new episode of Motor Trend’s Hot Rod Garage series, David Freiburger walks us through the process of swapping the brake rotors and pads in a 2005 GT, along with installing a new set of Ford Performance lowering springs. A new budget wheel and tire setup is also slapped on for good measure.
motor trend hot rod garage mustang
While the exact costs aren’t discussed, David does drop some rough estimates, and you should be able to do every modification here for less than $3k. For upgraded rims, sticky rubber, and autocross-ready brakes on a car that has been dropped an inch courtesy of new springs, that is basically a steal.
They test the car before and after the modifications, and I am sad to report that the springs did little to help autocross times, but the new brakes and rubber made a noticeable difference in speed, handling, and braking tests.
For the full run down of the exact parts they used, as well as the install process and the performance tests, just hit that play button below and enjoy.
via [Motor Trend Channel]
Christian Moe is hell bent on being the most unique and interesting auto writer you’ll find. He continually chases interesting stories and adventures that bring some freshness to the world of automotive journalism. He has worked with some of the biggest names in the business including Autobytel and Road and Track.
He loves all things motorized as long as they are old, interesting or have a good story. When not flogging a car down a local backroad he can usually be found several fathoms deep in some random body of water.
He also likes romantic drives and long burnouts by the beach.
