A/C Blend door possible fix (Worth a try).
![Lightbulb](https://themustangsource.com/forums/images/icons/icon3.gif)
(Re-syncing actuators) If you are having A/C air coming out warm on one vent & cold on other vents / or blend door issues, this simple fix is worth a try before delving into blend door motor replacement etc. Have done this & it worked for mine.
While car is parked. Start car & turn on A/C (Cold) WITH FAN SPEED ON MAX setting, run for 5 mins. Now turn to the highest (MAX) heat setting WITH FAN STILL ON MAX & run for another 5 mins. Return fan speed to normal setting & temp all the way back down. Now check blend door to see if fix has worked.
Palerider (5/26/24)
Received 2,712 Likes
Yep That is a Good One!
Moved You To Repair & Service Help For Easier Search!
Ran Across A Similar But a Little Different Procedure While Researching Some Other HVAC Issues The Other Day on an 05-09
Kc
Kc
Palerider (5/26/24)
Thank you for sharing your solution... Hopefully, this method will save other owners $$$ from having to take their cars back to the dealership for servicing...
![Thumb](https://themustangsource.com/forums/images/smilies/thumb.gif)
Received 2,219 Likes
Thank you for sharing your solution... Hopefully, this method will save other owners $$$ from having to take their cars back to the dealership for servicing... ![Thumb](https://themustangsource.com/forums/images/smilies/thumb.gif)
