2005 mustang crank no start
Hello
Last night I replaced my valve cover gaskets and replaced all my spark plugs and cables. This morning I go to start it and it cranks but no start. I checked everything and found my spark plugs aren’t getting a spark but everything is connected well. Any ideas? Thank you
Received 2,621 Likes
Welcome!
@patrickp
See Second To Last pdf on Post One!
https://themustangsource.com/forums/...e-info-550470/
@patrickp
patrickp (4/28/24)
I'll second that!
patrickp (4/28/24)
Got it started!
Got the car back up and running but now it’s spitting out a P0352 code for Ignition Coil B. I already have new spark plugs and wires so I’m at a loss of what it could be. Any ideas?
See Next PDF up From No Start.
Shows Codes And Diag Process.
I would Think if It Was Running Fine Beforehand a Wire Got Stretched and or Broken Where it Plugs into Coil Pack. Look For a Connector That May have Got Pushed Pack as Well in Connector.
If it is Running Good and Just Has Code Disconnect Battery For Ten Minutes or Clear Code if You Have Reader and See if it Comes Back!
