Transmission?
Old Nov 21, 2023 | 04:16 AM
RyanWeaver's Avatar
Transmission?
I have a 2010 mustang v6. It’s an automatic. I’ve had this car since I was 16, I’ve had to replace the transmission twice. It seems likes I had broken it again today. I was driving and came to a stop, when I put the car in drive it didn’t move, it just revved, same thing with reverse and same thing with third when it’s in the manual gear selection. I had this same problem the last time I replaced the transmission. Could this be something more simple?
Old Nov 21, 2023 | 04:00 PM
05stangkc's Avatar
Welcome!
Have You Checked For DTC Codes??
Need to Make Sure Fluid Level Correct as Well!
If & When Here are the Specific Ford Codes!
https://themustangsource.com/forums/...e-info-550475/
File Type: pdf
Old Yesterday | 04:27 PM
2Mustangs4Peggy's Avatar
OK - I have a 2013 Mustang V6 (ecoboost) and I just spent $6k on a rebuilt transmission. The first time it went out as a result of a hard stop. After that happened it immediately started to slip until it got to the point I could not drive it anymore. So I had the transmission rebuilt and not 6 months later it's happening again. Same thing - after I had to come to an immediate stop, the transmission started to slip again. My brother has a 2013 Ford Raptor - he had the exact same issue. He found something where there was a recall on the programming and or a recall on the "lead frame" which led him to believe there was an issue with a solenoid in the valve body. So it's not the transmission, it's this solenoid, which he had fixed and never had the transmission issue again.
lissuhllama
May 7, 2013 07:51 AM
Chaotic Bliss
Nov 27, 2010 10:04 AM
lou
Jun 23, 2010 09:42 AM
Rogue6
May 24, 2005 08:30 PM
