S-197 Convertible Top Issues / Window Motor Pdf's, LOTS OF FACTORY SHOP MANUAL PDF'S
Hi.
currently on vacation in south germany, and this problem started day 2. The soft top don`t raise in the right side. ?
anybody seen this problem before and maybe a fix for it. ??
2005 GT
2005 GT
Received 2,866 Likes
- The convertible top does not operate correctly
- Convertible top frame bows
- Convertible top side rails
- Hydraulic fluid leak
- Hydraulic lift cylinder
- Hydraulic motor and pump assembly
- Low hydraulic fluid
@Eliminator.dk
I Believe Issue is in Hydraulic System. Perhaps this Will Be Helpful! Sorry These are Online Interactive Pages and Somewhat Limits Usage.
If Anybody has Had This Issue Please Chime In!
See Section C1 in PDF3
The following 2 users liked this post by 05stangkc:
Eliminator.dk (6/19/23),
NC14GT (6/19/23)
Hmmm. doesn't look good in the movie you posted but make sure nothing is binding up. Have someone else operate the top while you look it over and "give the top some help lifting it up". Also make sure the joints are oiled or lubed and not too dry. Keep a rag towel under each section to keep the oil from getting all over the place. You can even use WD-40 and the towel will catch any overspray. Use another small rag to clean any excess from the joints you oiled. Simple enough tips but easy to overlook. No need for a mess. Good luck!
The following 2 users liked this post by NC14GT:
05stangkc (6/19/23),
Checking For Binding Certainly a Consideration!
NC14GT (6/20/23)
Thank You guys , i`ll do something possible here @ the vacation camp. …..But maybe first find a solution , when i get home in the garage. 😄
thanks for instruction pdf as well.
thanks again. 👍👍
thanks again. 👍👍
Hi.
Yes, my wife help to lift roof in the right side, and it`s possible to close it that way.
Do you think it can be done that way multiply times, without damage ?
Eliminator.dk (6/20/23),
NC14GT (6/20/23)
It's probably fine to do that manually if not forcing anything. Eventually something will probably break if done too many times. The glass is always scary.
Good luck finding the cause and we hope it's not too serious or expensive.
When I watch now, I can see the roof can`t hold pressure. No of the sides. Do You know if a checkvalve is in the system , and if a fix is possible ?
nothing is leaking. ?
thanks : Henrik
thanks : Henrik
BTMO,
NC14GT (6/23/23)
@thejak I Noticed Your Search Earlier & Thought These Might Be Helpful!
I Have Added More Content For Other Convertible Top Issues Besides Hydralics. Be Advised the S-197'S Tops Were Very Similar from 2005-2014. 2007 Factory Ford Shop Manual Sections!
This is Not For OP Concern But Others Seeking Convertible Top Information! I Should Have Started a New Topic! But I Did not! DOH!
Top Removal & Installation, Headliner, Bows Etc.
Enjoy,
Enjoy,
WIndow Motor Integration Information
2005 Mustang Window Wiring Diagram.
