Ideas
Build from the ground up. Tires and suspension first, then drive train, and then you can add power successfully.
As far as power adders go the most efficient ($) way to make hp is with nitrous. If you don't want to go that route you can pick the forced induction method that best suits your needs. They all have their pros and cons you just have to figure out which one meets your needs the best.
eaglebuc1020
1994-2004 V-6
7/8/18 09:07 AM
