I have a 2013 Boss 302 I bought w/salvaged title that was hit in the front bumper and replaced.
It is missing the sensor and the wiring. I know where the sensor goes, but cannot locate the connector.
I don't know if they chopped it off and taped it back into the wiring harness or what. I went to Ford dealership and they were useless only had a pic of the sensor.
Can someone next time there under the front snap a pic of the wiring and where it leads. It is the same as the GT model. I thought about going to a wrecking yard and looking, but in Houston it's 25 miles and horrid traffic to even get there.
-thanks in advance
Not sure if this is the help you need or not, but since I was away from my car right now, I thought this might get you started... Found this on American Muscle's site. If I can get something more complete before someone else does I will post it. Hope this helps.
-thanks in advance
shaneyusa:
Thanks for the quick reply. That second pic is helpful they didn't even have a pic showing the connector type. I need to know where the other end originates from. If all else fails I'll remove the bumper and start re-tracing the wire harness back and try and find it.
-thanks again
05stangkc:
Bingo..... that's what I needed ...... you even gave me the pigtail part number which Ford didn't even offer me ....... go figure.
Thanks very much for that and the quick response.
05stangkc:
You Are Welcome! Ford Parts Yep I Know a Bit About Them!
