GT350
Shelby GT350 Officially Gets 526 Galloping Ponies!
Old Jun 2, 2015 | 12:54 PM
AdPock's Avatar
TMS Editor
Thanks to a Road & Track tweet, we now know the official horsepower rating of the 2016 Shelby GT350 Mustang.
Read the rest on the Mustang Source homepage. >>
Old Jun 2, 2015 | 02:53 PM
It's "okay", I guess.
Look at that poor torque curve. Man,.....that is disappointing on how low and fast it drops off.
Old Jun 2, 2015 | 05:58 PM
dmichaels's Avatar
disappointing? over 100 hp/litre sounds pretty excellent to me. Perfect for road courses. Can't wait to see one out on the track
Old Jun 2, 2015 | 06:24 PM
5.M0NSTER's Avatar
526hp and ~425 tq? When can I get one of these installed in my S197??
Old Jun 2, 2015 | 06:57 PM
I will agree with you 100% about being on the road course or auto-x. That's some power and you don't need a ton of torque. And the high revving engine will do great for those events.
I do neither, so maybe that's why it doesn't appeal to me. It's still a nice car though, don't get me wrong.
Old Jun 2, 2015 | 07:25 PM
Joeywhat's Avatar
Are we looking at the same chart? It doesn't seem to drop off until 7k rpm (that's redline for everyone else...) and it doesn't exactly drop off fast after that.
Old Jun 2, 2015 | 07:29 PM
I think you're looking at the HP curve and not the TQ curve. TQ drops off rather quickly. The HP curve does go up and up. lol
Old Jun 2, 2015 | 07:38 PM
typesredline's Avatar
Originally Posted by Stage_3
It's "okay", I guess. Look at that poor torque curve. Man,.....that is disappointing on how low and fast it drops off.
I agree Joey. But this is a common post from Stage_3. He's very critical in a troll kind of way.
First off, 90% of the tq is from 3500 to 7500 rpms and it's far from "quickly dropping off". Secondly, the chart is not linear. The tq and hp columns are on different scales. Therefore the tq curve looks lower than it is in relation to the hp curve. If the numbers went up equally on each side, the tq curve would be higher vs the hp.
Plus keep in mind, higher revving engines can handle more torque multiplication through gearing.
Old Jun 2, 2015 | 10:02 PM
bob's Avatar
bob
Just means you have to drive it like you stole it. I find myself having to readjust my driving habits going from the Shelby (overdriven 2.9 Whipple) to the GT. Driven like the Shelby the GT feels lethargic unless I keep the revs between 3500 and 4000 rpm.
Old Jun 3, 2015 | 07:42 AM
bob's Avatar
bob
Anybody take notice of the 12:1 compression ratio and it's still port injected. By way of comparison GM's LT1 is 11.5 and direct injected.
Old Jun 3, 2015 | 04:18 PM
I will say this though,.....it's nice to see the HP stay up throughout the curve. The torque curve looks lower because it is lower. Is that not correct?
I don't understand what you mean the chart not being linear and the HP and TQ numbers are on different scales? Can you explain it so I understand it better? I'm not being facetious, at all, just want to know what you see that I am missing. Thanks.
Old Jun 3, 2015 | 04:33 PM
Joeywhat's Avatar
The left side of the chart reads torque, the right side reads power. The two are not scaled identically.
Old Jun 3, 2015 | 04:53 PM
Okay,.....I see it now upon closer inspection Joey.
Thanks for that.
Old Jun 3, 2015 | 06:17 PM
SpectreH's Avatar
If they were in the same scale, they would intersect at 5252 RPM.
Old Jun 3, 2015 | 11:24 PM
2 Go Snake's Avatar
Smile
From what I hear , the FPC engine is lighter than the coyote engine. Sounds like the FPC engine would make for a great engine in a 32 Ford street rod.
Old Jun 4, 2015 | 09:34 AM
P0 Corsa's Avatar
Unfortunately for those dreaming of installing the 5.2 FPC engine in ANY other car, I believe you will be pretty disappointed. The damping systems developed specifically for the GT350 application are complex and integrated in the engine/vehicle as a package system. Unlikely (IMO) this engine will be offered as a crate engine for just this reason.
Old Jun 4, 2015 | 11:40 AM
rmurer's Avatar
source?
Old Jun 5, 2015 | 06:03 AM
P0 Corsa's Avatar
Originally Posted by rmurer
source?
?? As I stated in my post it is In My OPINION (IMO) based on knowledge of the engine development program and my background. I might be wrong but time will tell.
But you have to ask yourself, now that the engine specs have been released, Ford is building (or close to building) and shipping the GT350 to retail customers, have you heard of this engine being offered by Total Performance as a crate engine?
Being located in SE Michigan, do you work for Ford?
Old Jun 5, 2015 | 10:43 AM
bob's Avatar
bob
That's cool, I would be mainly interested in the intake and heads and possibly the block if a cross plane crank could fit in there. The cams obviously are specific to the firing order of the FPC engine and it's valve events.
We've seen the run of the mill coyote eclipse 100 hp/l and rev to 8k or more.
Old Jun 5, 2015 | 12:06 PM
P0 Corsa's Avatar
From Car and Driver-
“Despite some similarities to the 435-hp5.0-liter Coyote V-8 in the current 2015 Mustang GT,the 5.2 is virtually an all-new engine from top to bottom; bore spacing and deck height are the same as the Coyote’s for production reasons, but little else is. The 5.2’s cast-aluminum block initially travels down the same production line as the 5.0 in Windsor, Ontario, Canada, but is bored out from the lesser engine’s 92.2 millimeters to 94.0 and blessed with other tweaks to reduce weight and cope with the greater output. The stroke has increased slightly from 92.7 millimeters in the 5.0 to 93 mm here, yielding 315 cubic inches of displacement.
The 5.2-liter V-8’s 32-valve cylinder heads have to cope with enormous stress during 8000-rpm blasts and were perhaps the greatest challenge for the engineers at Ford Performance. Taking advantage of the larger cylinder bores, hollow steel intake valves and sodium-filled exhaust valves are larger and more widely spaced than in the 5.0, and they’re governed by Ford’s Ti-VCT variable valve timing. The heads themselves are also fully CNCmachined, with additional production steps added solely to eliminate excess material. The profiles for the four camshafts are similarly aggressive, with monster lobes capable of raising the intake valves up to a gaping 14millimeters.”
Perhaps Bob, but there are a number of differences which will need to be considered for direct substitution.
