Sponsored by:
Sponsored by:
Weight Distribution
Old Nov 3, 2016 | 06:03 AM
gelbm3's Avatar
Originally Posted by Roadk9
@gelbm3 Here is some more info for you: A lot of guys worked to get this info.
Mostly taking their cars apart to upgrade them. Just like you.
OEM PP Shock Tower Brace: 7.6lbs
OEM PP K-Brace: 10.4lbs
OEM Front Subframe (K-Member): 58.2lbs
OEM Rear IRS Subframe (Empty): 55lbs
OEM IRON Diff Housing, Loaded - No Fluid: 99lbs
OEM IRS Halfshafts: 21.1lbs/each
FRPP Halfshafts: 30.2lbs/each
OEM Rear Lower Control Arm: 15.24lbs - each
OEM Rear Upper Camber Link Arm: 4.65lbs - each
OEM Vertical Link:
BMR Billet Vertical Link: 1.8lbs - each
OEM Rear Toe Link/Rod Arm: 2.42lbs - each
BMR Adjustable Toe Rod w/ Lock Out Plate:
OEM Rear IRS Cradle Mount Bushings: 1.05lbs - each
BMR Delrin Cradle Mount Bushings: .50lbs - each
OEM Rear IRS Diff Mount Bushings: .90lbs - each
BMR Billet Aluminum Diff Bushings: 1.47lbs - each
OEM Rear Lower Control Arm Bushings: 1.1lbs - each
BMR RLCA Bearing Upgrade Bushings: OEM EPAS Rack: 36.46lbs
OEM Motor Mounts: 3.9lbs - each
BMR Adjustable Motor Mounts: 1.9lbs - each
OEM Windshield Washer Fluid Res. w/ Fluid: 9lbs
OEM Battery: 31.31lbs
Deka ETX18 - 17.67lbs
OEM Catback Exhaust: 72lbs
Magnaflow Comp CB - 44lbs
OEM GT/V8 Passenger Side Header: 10lbs.
OEM GT/V8 Driver's Side: 19lbs
Borla GT/V8 Longtube Headers: 14.2lbs per side
OEM Base 18" GT Wheel w/ Tire: 54.5lbs
OEM PP Model 19" GT Wheel w/ Tire: F-60.6lbs / R-64.3lbs
OEM Dark Stainless Painted Aluminum 19" x 8.5" Wheel w/ Tire: 57.6 lbs
OEM Premium20x9 Foundry Wheel: 35.7 lbs
Billet Specialties 17x4.5 w/ MT SR 28" Radial - 39.8lbs
Billet Specialties 17x9.5 w/ MT 28" Drag Radial - 51lbs
OEM GT Cloth Seat: 50lbs
Corbeau FX1 w/ Bracket - 21.7lbs
OEM "Mid Pipes" w/ Cats: 22lbs
MAK O/R Pipes -
OEM GT Base 14" Front Brake Kit (Rotor/Caliper/Pads) - 43.8lbs per side (87.6lbs total L+R)
OEM GT PP 15" Front Brake Kit (Rotor/Caliper/Pads): - 47.2lbs per side (94.4lbs total L+R)
Aerospace 13" Lightweight Street Brakes (Rotor/Caliper/Pads/Brackets) - 19.4lbs per side (38.8lbs total L/R)
OEM GT 14" Base Front Rotor: 28.56lbs (57.12lbs pair)
OEM GT PP 15" Front Rotor: 33.4lbs (66.8lbs pair)
Aerospace 13" Lightweight Street Rotor - 14.3lbs (28.6lbs pair)
OEM GT Base Front Caliper: 15.24lbs
OEM GT PP Front Caliper: 13.8lbs
Aerospace Lightweight Front Caliper - 5.1lbs (10.2lbs pair)
OEM Front Sway Bar: 12.7lbs
OEM Front V8/GT Coil Springs: 4.8lbs - each
BMR Drag Front Springs: 3.95lbs - each
BMR Performance Front Springs: 4.8lbs - each
BMR Min Drop Front Springs: 4.75lbs - each
BMR Handling Front Springs: 4.8lbs - each
OEM Rear V8/GT Coil Springs: 9.7lbs - each
OEM Front Sway Bar End Links: 1.6lbs pair
BMR Adjustable Front End Links: 2.2lbs pair
OEM 2-Piece Driveshaft / Auto: 29lbs
OEM 2-Piece Driveshaft / Manual: 36.2lbs
Shaftmasters Auto 1-Piece Aluminum DS - 19lbs
DSS Auto 1-Piece Aluminum DS - 27.6lbs
OEM Front Spindle/Hub Assembly: 19.3lbs each
OEM Front Control Arm: 4.3lbs each
OEM Front Radius Arm: 6.8lbs each
OEM Front Tie Rod: 2lbs each
OEM Tire Air Pump: 5lbs
OEM EVAP Module/Canister
OEM Engine Sound Tube: 1.3lbs
OEM Engine Coil Covers: .75lbs/each
OEM Engine Cover: 3.4lbs
OEM Battery Cover: 1.23lbs
OEM Plastic Trunk Latch Cover: 2.40lbs
OEM Rear Seats: 30.8lbs
OEM Rear Lower Seat Cushion: 11lbs
OEM Trunk Carpet Cover: 4.6 pounds.
OEM Stock Floor Mats: 2.6 pounds.
OEM Carpet / Complete: 16.5lbs
WOW! What an amazing list. This belongs in some special place on the forum, not buried in this thread. How do we make that happen?
Old Nov 3, 2016 | 08:03 PM
Sarge's Avatar
Does anyone have any experience with a carbon fiber hood?
I was at trufiber.com browsing for S550 parts and saw they had a 40 lb fiberglass hood for $800, a 30 lb carbon fiber hood for $1800, and a lightweight 17 lb carbon fiber hood for $1800. That's a fair chunk of change for me and doesn't include paint, but it is a big weight reduction, and it's right over the front axles. If someone knows the OE hood weight, we can do the math and see how close that gets to 50/50.
Old Nov 4, 2016 | 08:06 AM
gelbm3's Avatar
I have little direct experience with fiberglas or carbon fiber replacements (other than some reading and being a mechanical engineer). But, I was about to post something similar. Just yesterday I was poking around under the hood and noticed (again?) how heavy the OEM hood is. Hood replacement is an ideal weight reduction goal for a vehicle that is a bit nose heavy as it reduces the weight where you want the weight reduction. It also aligns with two another weight reduction goals: (1) reduce the weight of things above the CG to ultimately lower the CG and (2) be careful of replacing anything that might decrease structural or torsional rigidity. Since the engine hood is above the CG and it is essentially a non-structural member, it is an ideal candidate.
I suspect that a good source for the weight of the OEM hood would be the very company that markets the aftermarket hoods. Worth also verifying with them that their hood has sufficient flex stiffness that it will not flutter at high speed. The air flow buffeting that goes on above and under the hood at high speeds can be a challenge. Also, probably a good idea to steer clear of glossy finishes on the hood as this will create glare.
Scothew
Curated Content Articles 2005-2009 Youtube & Photo Gallery
Jul 5, 2023 07:53 PM
unnoticedtrails
Toys and Automobilia
Aug 30, 2016 03:32 PM
