Sponsored by:
Sponsored by:
Vibration in steering wheel/chassis at 55 mph
Old May 5, 2016 | 02:41 PM
Dr Plastic's Avatar
Hi all
My GT has picked up a vibration in the chassis that starts at 55 mph and disappears at around 70 mph. One dealership stated that the vib is coming from the drivetrain. My main dealership checked the tire balance and said they could not find it. The tires were rotated and balance was checked and that did not fix the problem. They said that the last Mustang they had in the shop for that problem, they had it for 6 months and had to get Ford engineers involved. Is this a known issue?
Old May 5, 2016 | 07:45 PM
Praetorian730's Avatar
Is this an issue, no I would say this is a plague. May I direct you to this 76 page thread about it. http://mustang6g.com/forums/showthread.php?t=15990
And yes my 5 day old mustang also has it, noticed it the first time I took it over 50
Old May 10, 2016 | 06:36 PM
Dr Plastic's Avatar
Well dealership said that my ring and pinion gearset in the rear diff is bad. Waiting on parts to see if this will fix it!
Old May 10, 2016 | 07:06 PM
It seems driveshaft or ring and pinion account for nearly every fix, I myself plan to install an aluminum one piece. If that still doesn't fix it, ill be having them check the ring and pinion.
Old May 15, 2016 | 04:46 PM
buckethead1's Avatar
You'd think that with a century of manufacturing experience Ford could make a drive shaft that works.
Old May 17, 2016 | 06:16 PM
JohnnyMustang2's Avatar
My 2016 V-6 has it. Dealer replaced drive shaft twice and still have the vibration defect. I don't think it is a faulty drive shafts that is causing the problem. Some seemed to have had the vibration reduced after indexing the drive shaft. It's been about 8 weeks and am still trying to get it fixed. Ford Customer Service has not been much help.
Old May 26, 2016 | 09:34 PM
Dr Plastic's Avatar
Well the dealer stated that although they replaced the guts in the rear end, it still vibrates a little. not as much as before, but still buzzes. They are now going to replace the driveshaft!
Old May 28, 2016 | 02:21 PM
I'm considering installing an aftermarket one piece drive shaft. It appears the manufacturer is not going to fix it.
Old Jul 2, 2016 | 01:09 PM
Did you ever get the one piece driveshaft installed?
Old Jul 2, 2016 | 05:43 PM
Dr Plastic's Avatar
Well they replaced the driveshaft and it is smooth as glass now! They found that the pinion gear was bent and had a .004 variance in different areas around the gear.
Old Jul 6, 2016 | 03:20 PM
I wonder, what lead them to thinking it was the pinion gear? Before they replaced the gear, did the pinion flange have a visual wobble when turning ?
allen2016gt
Aug 30, 2016 06:23 PM
dohc97
Mar 9, 2016 07:00 PM
buckethead1
Mar 9, 2016 02:16 PM
Blown CS
Mar 4, 2016 10:34 AM
