Sponsored by:
Sponsored by:
Slight negative camber on rear wheels
Old Mar 9, 2017 | 02:41 PM
orlandoGT2017's Avatar
So I took my stang to the dealership the other day for an oil change, and while I was there I asked the technician who took care of me if the slight negative camber on the rear wheels is normal, or if I need to have it aligned properly. He said that with these cars that slight angle, and it is very slight, is to address the car when cornering. I can see how that may be the case if I am on a track all day long, however, I am not. Should I get this aligned properly? I have a 2017 GT with the PP package, lowered by 1 inch. Any insight is appreciated guys.
Old Mar 9, 2017 | 04:43 PM
SpectreH's Avatar
Most IRS cars have slight negative camber. As long as the tires are wearing OK, I would leave it alone.
Old Mar 9, 2017 | 06:38 PM
Appreciate the feedback. Will keep an eye on it. Cheers
Old Mar 10, 2017 | 06:41 AM
scott_0's Avatar
you actually want a little negative in the rear, as long as its within specs, which I believe is a max of -1.50
Old Mar 14, 2017 | 02:19 PM
Dr Plastic's Avatar
Did you get the car realigned after you lowered it? If not that is why you are seeing that negative camber.
Old Mar 14, 2017 | 07:51 PM
5.M0NSTER's Avatar
Negative camber will go a loooong way in taking a clover leaf ramp at ludicrous speed. How much negative camber do you have exactly?
I run -2.0 deg in the front. Rear is SRA so I can't change it. But I do track the car.
