Sponsored by:
Sponsored by:
Mustang Gt 2015 A/F
Old Dec 27, 2014 | 10:57 AM
v8ter's Avatar
Mustang Gt 2015 A/F
What arf are you seein on a stock gt? Mine is showing 11.6 at Wot and thats what I used to cee on my boosted 08
Old Dec 27, 2014 | 01:01 PM
m05fastbackGT's Avatar
You do realize that boosted cars are optimized to run within the lower 11.4 - 11.8 A/F right ?
The GT you have now is naturally aspirated and not forced inducted as your previous 2008 was.. Therefore your optimal A/F ratio for a naturally aspirated application should be within 12.5 -12.9 at WOT !
Old Dec 27, 2014 | 10:34 PM
v8ter's Avatar
That was the point I mentioned it,how would they tune the car to 11.6 on Na from factory
Old Dec 28, 2014 | 12:32 AM
That confused me as well, as it doesn't make any sense.. On a N/A car, an 11.6 A/F would be extremely way too rich
Old Dec 28, 2014 | 11:44 AM
MRGTX's Avatar
Are people seeing as-advertised fuel economy?
Whats the AFR at cruise?
Old Dec 28, 2014 | 12:38 PM
Victorfriessen's Avatar
Its around 14,and gas mileage seems to be a bit lower but I have a heavy foot but at cruising at 55mph it does 35 mpg avg on a tank mostly city is around 20
Old Dec 28, 2014 | 02:35 PM
The OP is referring to what his A/F ratio is at WOT, and not at cruise..
As I posted earlier, an 11.6 A/F ratio at WOT is way too rich on a naturally aspirated 4.6 or 5.0 !
Old Dec 28, 2014 | 09:15 PM
Five Oh Brian's Avatar
Running a little rich in an NA motor with 11:1 pistons probably isn't a terrible thing. My supercharged '07 GT ran 11.6 AFR at WOT. My NA '14 GT runs low to mid 12's AFR at WOT, but that's a custom tune. Not sure what it ran stock, but a little rich wouldn't have bothered me.
Old Dec 29, 2014 | 01:32 PM
Brian ! running just a little rich over extremely rich is a terrible thing and that does bother me..
My supercharged 06 GT has an 11.7 AFR at WOT which is normal and tuned correctly for a forced inducted application, however that's not the case when it comes to a naturally aspirated 4.6/5.0..
Just as you pointed out, your N/A 14 GT runs low to mid 12's AFR at WOT and for a custom tune, that's still considered as being somewhat on the conservative side..
At WOT, you should be looking at between 12.5 - 12.9 AFR safely with no issues whatsoever..
Now as for the 11:1 compression factor on the new 15's are concerned, perhaps that's why the AFR from the factory is 11.6 ? But that still seems really low at WOT for a naturally aspirated GT
Old Dec 30, 2014 | 11:59 PM
Better to run a little rich than to go too lean and put a hole through a piston. Running rich is the safer of the two scenarios by far.
Old Dec 31, 2014 | 11:34 AM
I understand what your saying Brian, but running too rich isn't really safe for your engine components either !
Old Dec 31, 2014 | 04:29 PM
David Young's Avatar
I think the OP needs to take his Mustang to his dealer and have them look at it. Maybe the gauge is off? Let us know what your dealer says about it.......
Old Dec 31, 2014 | 07:40 PM
Maybe that's all it is David ? At least lets hope so anyhow
PonyShow
V6
Nov 17, 2017 02:00 PM
tony2014mustang
Jul 23, 2015 10:56 AM
Jul 17, 2015 05:40 PM
bob
Jul 8, 2015 12:31 PM
